E36 Rack Conversion
Kedge
Going to have replace my steering rack fairly soon i reckon so have been considering this option.
Would i have any clearance issues on an M42 as i inderstand once the spacer is on the UJ?
I also want to double check whick track rod end you use, from what i've read the E36 ones join the E30 arms fine?
Is there a big noticeable from this rack to the E30s?
Is it going to cost me much more than simply buying a new E30 rack?
Dave
Dave
Andy335Touring
Templ8e30
The E36 rack makes a massive difference to the steering, feels a lot quicker and bags more feel.
One of the best mods I've done.
I believe you'll have bother with the coupling fouling the manifold on the iS. I had this problem with my BTB 6 branch.
I got around the fouling issue by cutting off the rack mounts and welding them back on 10mm further over to the drivers side. This gave more right lock than left lock so made up a 10mm thick lock-stop to fit to the passenger side of the rack to even it all up.
The E36 rack feels cack in my wife's E36 ! just like the E30 rack, the distance between the track rod end balljoint and the outer wishbone balljoint is greater on an E36. This means that the E30 wheels move further for the same turns on the steering wheel than the E36.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
stuartgallafant
Templ8e30
E36 318i saloon was the donor
I used the original E30 pipework but bent the lines with a blowtorch and pipe bender to suit.
I didn't use the modified joint used in the zone article, I used a standard E36 joint cut down and welded with an E30 knuckle fitted to the top UJ. Looks much neater and retains the rubber disc.
Cheers,
Iain T
Cheers,
Iain T
DRIFTBOY
Z3 steering rack is even quicker again the going from E30 to E36!
And it uses all the same fittings.
ian332isport
The modified joint described in the article also retains the rubber disc. Infact, the E36 rubber disc is a much stiffer item than the E30 one.Templ8e30 wrote:I didn't use the modified joint used in the zone article, I used a standard E36 joint cut down and welded with an E30 knuckle fitted to the top UJ. Looks much neater and retains the rubber disc.
Ian.
Templ8e30
So it doesian332isport wrote:The modified joint described in the article also retains the rubber disc. Infact, the E36 rubber disc is a much stiffer item than the E30 one.Templ8e30 wrote:I didn't use the modified joint used in the zone article, I used a standard E36 joint cut down and welded with an E30 knuckle fitted to the top UJ. Looks much neater and retains the rubber disc.
Ian.
Cheers,
Iain T
stuartgallafant
ian332isport
As far as I'm aware, it's externally identical to the E36 rack, so the same things need to be done.stuartgallafant wrote:so if you fit the Z3 rack, then you dont have to do any mods?
Ian.
DRIFTBOY
Yeah, sorry. I was rushing as I sneaked on to the zone at work!
Same fitting / mods as E36 rack.
Me and at least a couple of others on here did away with the rubber in the steering coupling. Doesn't seem to have any great negative effect.
Kedge
Cheers for the comments guys, think i might leave it for now because of the clearance issues and wait until i have a different engine in there which will have a manifold designed to fit this conversion!
Andy that link didn't work mate, says "You are trying to access a restricted area", weird!
Works for me OK. Someone suggested in might be something to do with the logging in on e30zone.co.uk, and trying to access a e30zone.net link.Kedge wrote:Andy that link didn't work mate, says "You are trying to access a restricted area", weird!
odbod
Schuey has a Z3 rack on his IS. It fits straight in with no UJ mods at all. It mounts in the 2 mounting holes further forwar than the standard mounts. Z3 is the quickest std rack you can get hold of.
Kedge
Got it working now Brian, think it was the .co.uk/.net problem!
That thread was a very interesting read, think i might go down that route! Just got to decide what to do about the spacers and whether to get some pipes made just incase i can't get mine in position!
Also anyone got any ideas if this would fit with an M52 conversion??
Will if you modify/make the exhaust manifold around the rack and shaft.Kedge wrote:Got it working now Brian, think it was the .co.uk/.net problem!
