Rear window removal and re-fitting
bmwe30mtech
Post Thu Feb 08, 2007 10:07 pm
Hi,
As title, whats involved in removing my rear window?
I need it out for changing my headlining.
Thanks,
Paul
Chris-W
Post Thu Feb 08, 2007 10:11 pm
Remove the two L pieces at the bottom corners (bend easily, take care). Remove plastic centre strips, upper and lower.
Remove heated window element connectors, 1 each side.
Push glass out from inside. Taking obvoius care! I'd start at the top edge.
bmwe30mtech
Post Fri Feb 09, 2007 4:40 pm
Thanks Chris. I have just removed everything i need to except the rear window (and its started to rain!), but i am stuck with the window.
You mention 'plastic centre strips'. What are these/where are they located?
Chris-W
Post Fri Feb 09, 2007 4:43 pm
The window surround rubber has a plastic strip inside it - it's in two pieces on the rear window; one along the bottom edge, and one running up the sides and over the top.
You need to pull these out - they create the tension in the rubber which holds the glass in.
bmwe30mtech
Post Fri Feb 09, 2007 4:46 pm
Thanks. I think i have just realised that these strips are on the outside of the glass, so i need to remove them from outside, then bend these 'L clips' from inside, then push the glass out from inside?
sam325is
Post Fri Feb 09, 2007 4:52 pm
you need to remove plastic beading from centre of seal like you say, the L shaped plates sit over the top of the beading in the bottom corners on outside, you want 2 people to get it out, one on inside pushing on one outside to stop anything getting damaged when it breaks out of seal, best of getting windscreen fitters to fit beading back in as its quite hard, will probly need new corner plates aswell
Chris-W
Post Fri Feb 09, 2007 4:53 pm
Yes, plastic strips are on the outside. The L pieces are just little metal fillets on the outside which cover the gaps where the plastic strips meet. Try *not* to bend them.
Push glass from inside, yes.
bmwe30mtech
Post Fri Feb 09, 2007 5:47 pm
OK, thanks guys.
Both back window and windscreen are out, i did it on my own but was careful so all went well.
Oh dear, i didnt know putting it back in would be hard! I will manage in the end im sure :mad:
Chris-W
Post Fri Feb 09, 2007 5:51 pm
Re-installation isn't that bad. Just infuriating. Once you get into a rhythm, it's quite easy.
bmwe30mtech
Post Fri Feb 09, 2007 10:19 pm
Well its a few hours later, and the headlining is mainly done. 'Just' got to do the sunroof section, and the front bit by the windscreen.
The back window is back in, but re-fitting the plastic strips is so hard, Chris, no rhythm has been discovered yet! :mad:
Post Sat Feb 10, 2007 12:10 am
The tool for refitting the locking strip can be bought for about £8. It's a diamond shaped piece of hard wire on a handle, and it only takes seconds to install the strip when using it.
carlos_320i
Post Sat Feb 10, 2007 1:26 am
I didnt know it was that easy :D Looks like I will be doing this the weekend
Chris-W
Post Sat Feb 10, 2007 8:13 am
Brianmoooore wrote:The tool for refitting the locking strip can be bought for about £8. It's a diamond shaped piece of hard wire on a handle, and it only takes seconds to install the strip when using it.
http://www.frost.co.uk/item_Detail.asp?productID=8104
ian332isport
Post Sat Feb 10, 2007 9:40 am
Getting the strips back in is not very hard with the tool shown above, but the corner pieces are a real turd to fit.
bmwe30mtech
Post Sat Feb 10, 2007 10:08 am
Thanks for all the responses. Zone is hugely helpfull.
I have to go to halfords today to get some stuff for my brother, so will look for the tool there.
Hopefully will be done tomorrow.
carlos_320i
Post Sat Feb 10, 2007 10:17 am
Looks like I wont be doing mine today as it is raining :cry:
E30Mark
Post Sat Feb 10, 2007 10:19 am
Halfords will not sell it, bung the bits in the car and pop into your local windscreen place, bung the guy a few quid and let him put the strips back in.
PM for details
bmwe30mtech
Post Sat Feb 10, 2007 11:19 pm
E30Mark wrote:Halfords will not sell it, bung the bits in the car and pop into your local windscreen place, bung the guy a few quid and let him put the strips back in.
Yep, they didnt do it.
Thats not a bad idea, so long as the glass stays in on the way down there. Will have to check out where the nearest place is.
carlos_320i
Post Sun Feb 11, 2007 12:29 am
Give a mobile guy a call mate he will come out to you I phoned up some companey and they wanted £50 to come out and swap them out
bmwe30mtech
Post Sun Feb 11, 2007 10:39 am
Cheers Carlos, but instead of fork out 50 i will be a cheap skate and give them another shot myself, otherwise i think their is a place on vestry estate.
By the way is that red e30 yours? I see a new one has appeared opposite your house. Also is your windscreen in the breaker any good? Im going to be re-Fitting my one with a big chip in it at the moment :?
ian332isport
Post Sun Feb 11, 2007 10:46 am
bmwe30mtech wrote:re-titting
:chuckle:
bmwe30mtech
Post Sun Feb 11, 2007 11:24 am
:chuckle:
Changed :wink:
carlos_320i
Post Sun Feb 11, 2007 5:19 pm
Yes mate that is my red E30 :D
And the windscreen has a scratch on it :( where someone has let the wipers were out
bmwe30mtech
Post Sun Feb 11, 2007 8:02 pm
Nice car the red one, i will have to take a proper look :D
I just finished everything with my roof lining (except the windscreen seals) , totally done, looks factory so im over the moon. Only took me 8 hours in total :eek: . NEVER AGAIN.
Im ordering a tool for the screens off the internet as i type.
