Frozen engine.... help.
charlE30
Post Wed Feb 07, 2007 4:15 pm
Just had a phone call from my missus asking to be picked up tonight due to her having to abandon the tourer (325i)on the way to work.. Apparently it was driving fine but had no hot air, the temperature gauge kept rising so she parked it up. She said she could hear what sounded like ice cracking when she opened the bonnet :cry: and yes it did have the correct amount of antifreeze in.
What (when I pick it up) should I be looking for to check damage? or will it be really obvious when I open the bonnet.
Any help on this one much appreciated chaps..
BMW F31 335d xdrive
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Wed Feb 07, 2007 4:18 pm
What makes you think its iced? did she check the water level? if a hose has split then it would over heat and the cold air hitting a very hot engine will make a clicking/ticking/cracking noise
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
charlE30
Post Wed Feb 07, 2007 4:26 pm
She reckoned she could hear what sounded like ice moving around inside, like ice cubes in a glass.
Water level a couple of days ago was fine and it dosen't loose water, I'm hoping it will just be split hoses but knowing my luck it'll end up being a cracked head :(
BMW F31 335d xdrive
wildeian
Post Wed Feb 07, 2007 5:31 pm
Air lock makes a similar noise
dazleeds
old skool raver
old skool raver
Post Wed Feb 07, 2007 5:47 pm
yeh id say it is prob an airlock
and what she can hear is the system pressurising :eek:
www.oldskoolfantasy.co.uk
charlE30
Post Wed Feb 07, 2007 5:55 pm
I've just been and seen the car, checked the water and oil (put about a litre of waterin) turned it over and it fired straight away as usual, left it ticking over for about 5 minutes. Air was blowing ice cold, couldn't see any leaks anywhere but when you try and open up the throttle it dies, release it and it goes back to a normal idle. Now it won't start again :cry:
If it had frozen (minus 7 degrees this morning) would there be any visible tell tale signs.
I hear what you're saying about airlocks but this car has always been really reliable, hot air within a few minutes.
BMW F31 335d xdrive
wildeian
Post Wed Feb 07, 2007 6:48 pm
If the car was started with frozen water in it, it would probably have blown a core plug. But if the water isn't running out onto the floor, then maybe something has gone internally :roll:
mrLEE30
Post Wed Feb 07, 2007 6:57 pm
a frozen engine is definately not good, ithe water expands in the rad and waterways causing all sorts of damage... core plugs, split radiator, knackered waterpump, warped head ect etc but a fully frozen engine would be obvoius as the water pump would not turn and the fan belt would screech like hell!!!
if the car will not start this cannot be related to the issue of no hot air. first thing to check is the air flow meter especially the plug on the top as removing this would cause simlar probs to your symptoms. if not this then post again
if you do get it started then check for air and bleed air out of the system, you added a litre which is quite a lot of water!! as its a tourer its the later M20 engine so an 8mm bleed nut on top of the thermostat, turn heater to full hot and loosen the nut, leave car running till air no longer comes out of bleed, tighten keep running the car and open the nut again once fully hot with engine off, if air comes out keep nut open till water comes, then close nut start car and repeat till only water comes out.
