Hey I could do with some Advice with my cabby. A few weeks ago I hit the sump and put an inch long gash in it. I didn't realise at the time so it seemed odd when it started running like shit. The oil light came on so I took it straight to my garage and put it on the ramps. Fixed the hole and filled it with 10w40 (it was all I had).
A week later it started making a bit of a knock, so I changed the oil for 15w40. It hasn't got any worse, but It still needs new bearings. Bearing in mind this is a 320i, would you rebuild the existing engine? Or buy another lump? It's started leaking oil from the rear crank oil seal and it killed my prop coupling, fitted a new one today and it already making the same symptoms as the old coupling (oil contamination?).
Really losing heart with this car...
Opinions please
maxfield
you can put a 325 engine in for less than £300
jbee
may as wellmaxfield wrote:you can put a 325 engine in for less than £300
bigkev
you may get away with some new shells which can be fitted in place depends on the condition of the crank, the rear crank seal is nowhere near the coupling so i dont know whats going on there as the rear seal is in the bell housing and the coupling is at the rear of the gearbox the worst that can happen is a slipping clutch , dont you mean a leaking gearbox output shaft ?
if you can do the work yourself all it will cost you is a sump gasket and some shells so worth a go i say, all depends if its a daily driver i suppose
good luck
good luck
GingerTim
I'd go for that.maxfield wrote:you can put a 325 engine in for less than £300
JonDubber
The oil is dropping from the hole at the front of the bell housing - being blown back whilst driving. You say it can be done in place, does the subframe have to be removed? Or does the engine have to be lifted slightly to get the sump off? I've priced the parts up in work - looking at around £25 for big ends and main bearings.bigkev wrote:you may get away with some new shells which can be fitted in place depends on the condition of the crank, the rear crank seal is nowhere near the coupling so i dont know whats going on there as the rear seal is in the bell housing and the coupling is at the rear of the gearbox the worst that can happen is a slipping clutch , dont you mean a leaking gearbox output shaft ?
good luck
Where's the best place to get a Bentley manual for this?
if you do pull it out, why not go the 2.7 route etx bottom end with a 2.0 head.
You would be mad to rebuild a 2.0 imo. There's plenty of secondhand 2.0 lumps about too for little money
JonDubber
You make a good point, but unless the engine is still in the car, there's no way of telling whether its a good one or not. VW engines I can get good ones as I've been in the scene for years and made friends I can trust, but I haven't been in the BMW game for too long.Simon13 wrote:if you do pull it out, why not go the 2.7 route etx bottom end with a 2.0 head.
