Any of you guys removed the heater matrix and replaced it with a smaller lighter item? If so which one?
My friend just changed his VR6 one for a Polo version and saved himself a good few KG's in the process.
Before anyone asks i'm not getting rid of it 100% as window clearing and a little heat is important to me.
Heater matrix
Davenotouring
Jesus, heater matrix weight? It can't weigh more than a kilo?!
This is getting serious.
BMW 328i Cab - Daily Slag
Davenotouring
Yeah but we're talking about replacing just the matrix itself for a smaller unit. Doing any with the whole system is a different matter.
Davenotouring
Then yeah, go for it and deal with no heaters! Then it's worth it!
- buster
Dont mini's have little ones ?
Also some kit cars use universal ones which are quite compact.
I think you can get small electric ones also just for demisting the screen so no need for the heater matrix.
Andy335Touring
- Contact:
I think i read some where a chap had two E36 rear cabby heater fans fitted to his E30 track car, they were fairly light if i remember ?buster wrote: I think you can get small electric ones also just for demisting the screen so no need for the heater matrix.
The other way is to get a heated screen like Dave says. Have a look at Taffy's web page as i think he does them ?
alternatively go to the bog and have a good dump before going out and track- that should save you at least 2 kg !!!
i still have the original heater in my stipped track car - i use it loads in the winter as its bloody cold out on track fo the first hour or so !!!
ps - stay clear of the mini / kit car ones...i have one in my kit car and you get more heat from lighting match and more blow from a bike pump !!!!
