Stud extractor needed?
eko
Old timer
Post Fri Feb 02, 2007 10:27 pm
I need advice on stud extractor to use to remove snapped bolt that is flush.
Please refer to this thread for details -
http://www.e30zone.net/modules.php?name ... ic&t=56765
eko
Old timer
Post Sat Feb 03, 2007 12:32 am
Anyone?
Templ8e30
Post Sat Feb 03, 2007 8:48 pm
Not a hop in hell of getting that out without removing the diff IMO
It'll need drilling dead centre and an easy-out or something similar to extract it.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
eko
Old timer
Post Sat Feb 03, 2007 8:52 pm
Templ8e30 wrote:Not a hop in hell of getting that out without removing the diff IMO
Cheers,
Iain T
Exactly my thinking too :?
Was thinking about how ill go about it before,do you think some heat on it will loosen it?
Or is this likely to make the job worse?
Maybe hacksaw a slot into the end,obviously itll cut into the housing a bit to,then warm it up and try and impact screwdri9ver it out?
Andy335Touring
Post Sat Feb 03, 2007 9:37 pm
Can you get to weld an old bolt or some thing on it ?
eko
Old timer
Post Sat Feb 03, 2007 9:42 pm
Andy335Touring wrote:Can you get to weld an old bolt or some thing on it ?
Not sure to be honest?
Be a damn site easier if i could get it on a ramp though :mad:
Going to get it up on ramps tomorrow and have a closer look,bit of head scratching,then probably get the tools out and starting taking the b4stard out :mad:
fuzzy
He who sleeps with "Gingers"
Post Sat Feb 03, 2007 10:06 pm
cant see you being able to weld on to it tbh. wouldnt be to difficult to remove with a stud extractor but will need the diff removed which isnt a difficult job either.id reckon half a day to finish it.
e21Jason
Post Sat Feb 03, 2007 10:56 pm
Hi
Try some Irwin bolt extractors
http://www.irwin.com/irwin/consumer/jht ... nCat100511
Bought a set as I had a hexbolt round of one the inside, used loads since i show my nuts no mercy
Jason
M3Compact
Post Sat Feb 03, 2007 11:07 pm
Cheers,
Iain T
Agreed unfortunately. :(
Taking the diff out's a pita. :roll:
But...Wasting hours and getting pi55ed off, then taking the diff out is a bigger pita. :(
Templ8e30
Post Sun Feb 04, 2007 5:43 pm
These would work better in this case http://www.irwin.com/irwin/consumer/jht ... Prod100510
Cheers,
Iain T
bennyboy
Post Sun Feb 04, 2007 7:42 pm
Halfords do a set of Lazer stud extractors for about £6-7. i used these to get my wheel nuts off when i lost the key. Just drill into the centre of the stud/bolt and wind one of them into your drill hole. They are a reverse thread so when they go tight they start undoing the bolt. Good luck dude!
16V IS engine!!!
