M30 throttle bodies
Aragorn
aren't u a little worried about boost distribution across all 6 pots, turbo plenums are usually tapered to try to keep flow even across all cylinders, u may find that the front few cylinders end up running lean and rears rich due to the distribution on that plenum!
Toby_Unna
- Boost Junkie
Don't really know TBH. if there ends up being a problem, i reckon moving the plenum intake to the middle of the face (below the 'M') should help. Remember though that this isn't some little four pot running 2 bar of boost; at 1 bar, i reckon i stand a good chance of being ok.
aragorn - i'm not worried about anything to do with this engine. it didn't cost much and there are plenty more arpund if it does go bang
glenn
- Engine Transplant Services
you've got it running then
you magician you!
well done mate.
i'm sure ant will sweeten it up for you
a bar of boost with that engine, in that car?..............WOW!!
i dont think you'll have any issue's with being lean/rich between front/rear
you magician you!
well done mate.
gareth
at least if it does prove to be an issue and do some damage like melt a piston (£100 engine bill!!!
), whip the plenum off, move the inlet to the middle of the plenum, relocate the header tank and the jobs a goodun! not too much sweat in the scheme of things
Andy335Touring
Chuft to bits you got this going dude, i thought i'd given you a mission imposible by giving you those TB's
How did the porting of the plate go, not fun i guess ?
I need to get mine sorted now
Toby_Unna
- Boost Junkie
Andy, nothing's impossible
plate took a lot of filing, the ports aren't perfect but they'll do.
Cheers Glenn
on 1 bar it'll probably be about as quick as your standard S62
gotta get the thing running properly before the boost goes up though!
Cheers Glenn
ric325i
get-in the monster lives!
good read as usual!
once mapped its gunna be scary
good read as usual!
Toby_Unna
- Boost Junkie
Got this mapped now, courtesy of Ant yesterday. so after washing it for the first time in about 9 months i decided to take it out for a proper drive this afternoon.
verdict? well pleased
it's still a little shaky low down thanks to the throttles being a bit on the large side, but Ant worked very hard to remove various flat spots yesterday and it's very driveable on light throttle; with more time this should be possible to make perfect.
more importantly, on full throttle and at high revs it pulls noticeably harder than it used to, and sounds f**king cool under load in high gears
throttle response is vastly improved over the single TB setup too. and apart from the thermostat which i think is sticking open, the shonky cooling plumbing is perfect.
have to say thanks (again) to Ant. it wouldn't be running without you dude
http://www.e30zone.net/modules.php?name ... ic&t=58310
DRIFTBOY
Nice one Toby (and Ant!).
Glad all the hard work and headaches seem to have paid off for you!
That E30 must be dangerous!
Andy335Touring
Fantastic, bet you are glad they sound better as you said it's the one thing you miss since sticking the turbo on
I can't wait for a ride in it, get it on the rollers again
Did you tweak the boost up ?
Toby_Unna
- Boost Junkie
no, still 7psi mate
it'll go up eventually but i'm quite happy with it as-is for the moment, feels nice and quick
Martin, i've just taken it out in the rain and can confirm it is indeed 'dangerous'
going to have to bite the bullet and get some 16" wheels to put bigger brakes on too, shame as i really like my mim 15s
- Homo Hair
Gutted bout the loss of the 15" MIM's Toby! I love them on your car!!! What about the WMS upgrade? they can supposedly fit under 15" wheels..
Car is nuts now! Def think you should be turning up the boost a little tho n getting it R/R'd! Dont be a wuss
In the meantime all ive still got the plumbing wiring n exhaust to do on my S50
*Hangs head in shame*
robmarriott
Toby, what Intercooler are you using?
I remember reading it, but can't remember what it was
Silverfang
From memory (after reading on the PPC mags) its a volvo 740 item i think
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
gareth
toby, do you have a spare mim wheel? i'd happily check fitting on my setup if you post it to me!!!?
i promise you can have it back afterwards!
it's really down to the shape of the wheel... it will fit under a 15" BBS but mims have not been tried yet.
Toby_Unna
- Boost Junkie
Just the four i'm afaid Gareth, the spare is a 14" bottletop
that's going to be fun if i ever get a puncture isn't it.
Rob, it's a volvo 740/760 petrol one. it's the taller version from a T3-turbo'd car, some of these volvos (the ones with a mitsubishi turbo) have a similar but less tall IC.
Ritchie
I dont suppose you know how tall do you Toby?
Ive got one for future use but no doubt it will be the wrong one!
Toby_Unna
- Boost Junkie
somewhere around the height of the m535i rad, if that's what you're using?
i'll stick a tape measure on it when i get a chance
gareth
i had to use a 14" bottletop on the rear when i got a puncture... the others were 17" alpina repsToby_Unna wrote:Just the four i'm afaid Gareth, the spare is a 14" bottletop![]()
next time you have a wheel off, if you knock up a carboard template of the profile of the inside of your wheel and post it to me or keri-wms we'll offer it up for you on my car and see how it compares
Toby_Unna
- Boost Junkie
cheers Gareth, WMS would be nice though possibly little out of my budget.
Ritchie
That is the rad im using, cheers mate.Toby_Unna wrote:somewhere around the height of the m535i rad, if that's what you're using?
DieselMeister
Toby for President.
Ant can head up the ministry of boost
