flap drive motor
DaveD
- E30Zone Wiki Specialist
has anyone refurbed the gears on this
Simon
What's a flap drive motor?
Potentiometer on air flow meter?
DaveD
It is the centre motor on the convertible roof set ut that moves the roof cover (flap in BMW parts speak) up and down along with locking it
E30cabalan
I have done both motors but the biggest problem is making sure all the microswitches stay in the correct orientation.
What do you mean by refurb? Is the motor gearbox damaged.
As you probably know the lacal BM stealers will take your wages at the door for one of these motors as a replacement.
DaveD
hi
we have had it out and the gears are worn so am asking a local auto box repaiter to have a go ...my mechanic says it looks an easy repair if you know what you are doing...its better than Ԛ£200+ for a new motor
E30cabalan
If you are stuck for the gear parts for repair try www.hpc-gears.co.uk.
If your local chap is any good with lathe etc it is easy
cabrio327i
Hi Dave, I have a complete motor and gearbox with perfect gears ! the only piece thats missing is the part that allways breaks which is the gearbox end casing, if its any use to you make me a offer, im sure it would be better than trying to source after market gears, cheers Dave
DaveD
Hi
I think you have the hood drive motor..I have replaced that and have my own broken one .. it is the centre one i am looking at replacing..on this the casing is ok
DaveD
The cost to refurb was more than a new motor but have found a used one from a guy called jason in the west midlands.specialises in convertibles..anyone used him
He says he does a repair kit for the hood motor..a new top casing in mild steel.. more info to follow as I will go and get the new motor on monday or tuesday
M3RAGS
ah, that would be Jason from Birmingham. Never used him but he is recommended from Nigel at Moseley so cant be bad.
Sideways S14
woodysjw
I have used him and he really is a Top Bloke, real nice to deal with
and cant do more to help posted my bits out same day and i got them
9 30 the next morning
796 - 1989 Motorsport Edition
DaveD
seems that way
i might go down and look and see what he does...let you know
