3,91 diff on a 318is cab???
bennyboy
My cab had a 4,27 from new. this broke. i replaced it with a 4,10 for now as this one isn't very good either. i ordered another diff from bmc before xmas and i have been sent a 3,91. they insist it came from the 318i cab they were breaking. anyway, is it worth putting it on or will it make the car to slow?
16V IS engine!!!
cliffybabe
- Powered by Nelly
na a 3:91 is ok for a 318i, i dont think it will slow it down but im sure one of the guys will confirm
bennyboy
i really wanted a 4,27 though. the car was still good for 130-140 but never need that. just wanted it to be a bit nippy really. my limiter comes in at 6500rpm. with the 4,10 in there, in 5th, its doing 75 at 3250rpm. so its geared for 150 at the moment but with less acceleration. just thought the 3,91 would really slow it down (acceleration)
16V IS engine!!!
cliffybabe
- Powered by Nelly
i think it does bring it down a bit
When i got a new dif for the 318i shitter i had i got a 4:10 and was told it would make it a nipy motor with that on it
stuartgallafant
eamo
you will notice a slight difference alright going from a 4.27 to a 3.91
acceleration up through the gears will be slower but your top end will be extended slightly
I swapped the diff in my old m3 which was a 3.25 for a 3.64 and imo transformed the car for the better. acceleration up throught the gears was excellent
Bob_S
i noticed a difference going from a 4.1 to 4.27
I would think a 3.91 is too long for an is especially a cabby too
Bollocks to this 24v scrap!
bennyboy
Stu, i think its a small case. the 4,27 is in my garage but going to the tip soon. one of the two, or maybe both prop bearings have gone in it. was going to rebuild it untill i found out what was involved.
When i went from the 4,27 to the 4,10, i noticed the acceleration suffer. A difference of 0,17. Now another 0,19.
Think it might have to go on anyway because i have just started a new job and need the car.
16V IS engine!!!
miniblob
I get the feeling Stu may have plans for that 4.27
327 Touring with bass!!!
stuartgallafant
