M20 flywheel on S50 / M50 / M52 swap.
m-dtech
Unapproved Trader caution
Post Fri Jan 26, 2007 9:30 pm
DanThe wrote:Theres nothing good about an M40 flywheel, its just a big unnecessary lump with a smaller diameter clutch
yep, i agree with that.
had both side by side and compaired, i decided to go with the dual mass m50 clutch and flywheel.
Means i can use the standard starter etc and the clutch is bigger :)
Might consider upgrading at a later date.
jmc330i
Post Fri Jan 26, 2007 9:35 pm
m-dtech wrote:i decided to go with the dual mass m50 clutch and flywheel.
Which gearbox are you using though?
Im trying to figure which bits I can use - I have full M20 and M40 stuff, so mixing and matching is not a problem.
James
'91 325i Sport
'93 318i touring 16v
m-dtech
Post Fri Jan 26, 2007 9:53 pm
im using the m40/m42 gearbox.
jmc330i
Post Fri Jan 26, 2007 9:56 pm
im using the m44/m42 gearbox.
So its possible the M50 dualmass flywheel and clutch would fit with the M40 box?
James
'91 325i Sport
m-dtech
Post Fri Jan 26, 2007 10:12 pm
jmc330i wrote:
m-dtech wrote:
jmc330i wrote: Which gearbox are you using though?
yip, fits perfectly.
m40 box is almost the same size as the e36 box.
jmc330i
Post Fri Jan 26, 2007 10:39 pm
So I have no real reason not to do an M50 swap then :)
I have all the parts needed, just need to get an engine. Damn BMW for making things so easy :x
James
'91 325i Sport
m-dtech
Post Fri Jan 26, 2007 10:45 pm
im still not sure on propshaft though....... was thinking might get away with 318i prop ??
jmc330i
Post Fri Jan 26, 2007 10:53 pm
Good point.
I do have both 318i and 325i props at home but thats not much use without an M50 under the bonnet :roll:
Logic would say the 318i prop would be the one because of the gearbox length. I guess it would depend on what effect the M50 has on the gearbox position.
James
'91 325i Sport
m-dtech
Post Fri Jan 26, 2007 10:58 pm
jmc330i wrote:Good point.
compaired to the e36 box the m40 was about the same.... i should be able to tell you tomoz when i trial fit the engine and box.
jmc330i
Post Fri Jan 26, 2007 11:04 pm
m-dtech wrote:i should be able to tell you tomoz when i trial fit the engine and box.
Nice one :thumb::
James
'91 325i Sport
m-dtech
Post Sat Jan 27, 2007 8:02 pm
im fabricating my own mounts to move the engine forward as its roughly 2.5 inches too far back.
will take exact measurments tomorrow and try again.
gotta move the engine forward to get the gearlinkages to work etc.
Post Sat Jan 27, 2007 8:16 pm
Surely there are some linkages that will work, they are all very similar in design.
I shortened the linkages for my E46 box by 50 mm
m-dtech
Post Sat Jan 27, 2007 8:20 pm
DanThe wrote:Surely there are some linkages that will work, they are all very similar in design.
yeah its 50mm too far back, and prop is 50mm too long.
rather than modify linkages and get a shorter prop im just gonna make mounts.
Post Sat Jan 27, 2007 8:30 pm
But you will also move weight even further over the front wheels which will compromise handling.
Not worth it IMO.
m-dtech
Post Sat Jan 27, 2007 8:42 pm
soon see. 50mm is not much,
its about --------------------------------- that much lol
jmc330i
Post Sun Jan 28, 2007 6:11 pm
Which prop is too long - the M40 prop?
James
'91 325i Sport
m-dtech
Post Sun Jan 28, 2007 6:48 pm
The prop on the IS is too long.
Im guessing that the IS prop is the same as the m40 as the boxes are the same.
still deciding my next course of action.
move engine forward or shorten gearlinkages and fit m20 prop.
Post Sun Jan 28, 2007 6:53 pm
M20 prop and find some linkages from an E36
m-dtech
Post Sun Jan 28, 2007 6:56 pm
having taken some more measurments,
the m50 is pushing the gearbox 60mm further back than normal.
jaistanley
Post Mon Jan 29, 2007 9:58 am
So with an S50 and the 328i/M3 3.0 gearbox (which I beleive goes on with an E30 M3 prop) which gear linkage will be needed? I've got a bit lost.
Jai
jmc330i
Post Mon Jan 29, 2007 4:19 pm
jaistanley wrote:So with an S50 and the 328i/M3 3.0 gearbox (which I beleive goes on with an E30 M3 prop)
Thats right.
I used the E36 M3 gearstick and IIRC, the M20 shift arm and selector rod.
Im 99% sure that I used the M20 parts. I know 100% that I used the M20 shift arm (the bit that goes from box to body) and I know I used whichever was the shortest selector rod (M20 or E36 M3) so the gearstick (E36 M3) was centered front to back. With the longer selector rod, the gearstick hit the center console in 1st, 3rd, 5th and Rev.
James
'91 325i Sport
M-technik3
Post Sun Feb 04, 2007 3:38 am
Brianmoooore wrote:
ste wrote:but I don't trust Americans to have much intelligence.
Know what you mean, but there are a few on here, so I wasn't going to say so! Ian (Haynes) posts on there and points them in the right direction from time to time.
Love this comment... I have been driving my swapped car for 6 years now. Us silly americans know squat.
