slave cylinder
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Wed Jan 24, 2007 11:19 am
Hi - seems that in additional the engine mounts I've got more work todo. I couple of people have mentioned slave cylinder is the problem.
I drive in the morning and left my car park in a cark park, came back to it drove off fine, two minutes down the road I noticed the bite point on the clutch was getting lower and lower until the clutch wouldn't disengage. Opened the bonnet to find it was out of fluid, topped it back up and got home only using the clutch to pull off. Left it for a few hours, came back and it had emptied itself of fluid again.
Anyway - question is, do you guys agree with it being slave cylinder and if so - how do I change it ?
Chris-W
Post Wed Jan 24, 2007 11:24 am
Well, it's most likely the slave, but could be the master or even the hose from the reservoir to the master (could also be the rigid line, but it's very unlikely).
Check the reservoir hose first, if that's OK then it's one of the cylinders, but replace both master the slave.
Master unbolts from inside the drivers' footwell and is fiddly / time consuming, slave simply unbolts from the LHS of the gearbox, access from underneath the car. Bleeding the system will take some time if you do it manually.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Wed Jan 24, 2007 11:36 am
Thanks. I'll check the things you mentioned first. Any way to determine if the master or slave needs doing? I'm not keeping this turd more than two months and just want it driveable in the meantime.
Cheers,
Ashley
Chris-W
Post Wed Jan 24, 2007 11:40 am
A pool of hydraulic fluid underneath either!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Wed Jan 24, 2007 12:28 pm
lol- good point. will check later.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Wed Jan 24, 2007 1:52 pm
just one more thing. On GSF they have master and slave cylinders but there's two listed - each type has " ... cylinder" and "... cylinder-BQ".
the BQ is more expensive, is this an OEM one, or are that completely different parts?
Post Wed Jan 24, 2007 2:10 pm
BQ ones are likely to be from one of BMW's OE manufactuers. (They use more than one).
The cheap ones are just that!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Wed Jan 24, 2007 2:11 pm
cheap one it is - see above post for rationale.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sat Jan 27, 2007 3:06 pm
ok - slave is out. just waiting for housemate to get me to GSF and I'm good to go.
What's the procedure for bleeding?
1. undo nipple
2. press pedal
3. lock nipple.
4. pedal up
5. repeat
**BANNED**
Post Sat Jan 27, 2007 6:19 pm
uup
Chris-W
Post Sat Jan 27, 2007 6:20 pm
Remove reservoir cap & keep a good eye on the level!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun Jan 28, 2007 2:21 pm
cheers.
Would have had this completed yesterday but I missed the closing time for GSF so gonna try and get part tomorrow.
No driving to work for me tomorrow :(
