Templ8e30 wrote:I converted one a couple of years back, needed the following:
Gearbox
Propshaft
Flywheel
Clutch
Spigot bearing and related cup/washer/felt ring
Gear linkages and mounting parts
Gear lever and gaiter
Pedal box
Clutch slave and master cylinders with piping and fluid reservoir with bracket
Gearbox mounting bolts (iirc they're different lengths)
Can't remember if the centre console is different or not.
There is a starter inhibit switch on auto's (stops you starting it whilst in gear), Brianmoore will be the expert on this as I can't remember which bits needed attention.
Iain T
Add to the list: The short wiring loom for the reverse light switch to the connector at the bottom of the gearlever, inside the car.
Goes through the gear lever grommet, and may still be attached to it.
Centre console is the same, although there's a little metal bracket that has to be removed.
Starter inhibit: Above the glovebox you will find two black, round single pin connectors, each with black/yellow wire coming from the main loom.
Unplug the wiring from these two connectors and plug the two connectors from the main loom together. You can then remove the inhibit loom and its relay completely from the car.
