335i water hoses, and a noob the e30 zone! Hi.
BristolBulldog
Post Tue Jan 16, 2007 5:07 pm
Ok, i have been on loads of other forums, never on this one. Fed up of hearing guesses by people who have no idea on what someone is asking, so have come to this forum with some hope on something i am definetly struggling on.
I used to run www.335itc.co.uk. not sure if anyone ever heard of it, or got on there. It will come back, just not on that address.
I havnt touched the car in a while, and with the tiniest bit of nice weather today, and it being a new year and all that (and my 635 sold, due to be picked up alter in the week), i have renewed enthusiasm. I have sent off the last part for the leather re-trim to be finished as well. sop Progress has begun again (3rd year now!).
most of the car is done, i have nowhere to host images anymore, so havnt got any to show (unless youemal me!, or want to host some for me(i used to do it for about 20 other people).
The chassis is mostly done, suspension overhaul done, engine in, box fitted, diff converted, genune m3 kit fitted, re-trim 90% done.
What i am stuck on is the bloody water hoses. I just need the part numbers for the water hoses i need. The hoses i have arn't the right ones, and i didnt ideally want to join two together. I will buying new hoses. the engine i have is the 218bhp type (first temporary engine), so there is not water takeoff at the back of the head.
if anyone ahs the part numbers i would love you (in a purely textual manner (sorry)).
If you want to know anything else let me know. I have gone from almost the 1st bolt, and have done most of what needs to be done, so sure i can return the help to others.
thanks.
Aiming for yet another summer lol!
ed325i
Post Tue Jan 16, 2007 5:40 pm
Have a look here >> http://homepage.ntlworld.com/a.law47/33 ... uring.html
And for part numbers look here >> http://www.realoem.com/bmw/
I have been on your site.
Hyperion
Post Tue Jan 16, 2007 5:57 pm
Hi Welcome.
If you have pictures and need to host them use http://www.imageshack.us/
Here is a write up on how to do it.
http://www.e30zone.co.uk/modules.php?na ... ic&t=24039
BristolBulldog
Post Tue Jan 16, 2007 6:25 pm
excellent thanks. I will see if i can get a look in later.
Andy335Touring
Post Tue Jan 16, 2007 6:39 pm
You are probobly not going to find a single direct fit hose but you should be able to mix and match some hoses/connectors from different M30 powered cars.
This is how the E34/2 cooling pipes are....
On your generation M30 (E28/4 ?) you don't have the pipe that comes off the top rad hose so i think the pipe off the back of the head serves the same job in that you can connect it to the bottom connection on the bulk head for the heater core.
Which expanction(sp?) tank and exhaust manifolds are you using ?
BristolBulldog
Post Tue Jan 16, 2007 6:50 pm
Using the e32 type. The confusion i had was when i had to link to the heater matrix. The six i had, had the older type e24, so the rear of the head link was there, further confusing me!
The diagram above looks like a full diagram, with the only left open outputs being the back two (in the diagram), that link to the heater matrix?
Modifying these hoses is not such an issue. I need to know the flow for the e30. i think its inlet in the top pipe, and outlet from the bottom. the hose that splits from the right of the thermostat housing is the output or input? Just trying to get the final details!!!
DRIFTBOY
Post Tue Jan 16, 2007 7:03 pm
The top hose on the heater goes to a small port on the thermostat housing (no. 6 in picture), the bottom heter pipe joins to the hose which is 'T'd' off the radiator top hose (no.1 in picture).
And welcome! :D
Look forward to seeing this website of yours and some pics of your 335!
BristolBulldog
Post Tue Jan 16, 2007 7:12 pm
i think i need to order a complete set for the e32 and see where i come short, then adapt them from there. It does seem like the e32 pipe's have the right connections, with just lengths being the issue?
anyone have a e32/ e34 based 335i e30? would be good to get some engine bay shots, and maybe some tips on how they extended the hoses. Unless the whole, hollow pipe and jubilee clips is the best?
Andy335Touring
Post Tue Jan 16, 2007 7:20 pm
This is my set up, E34 M30 with out the pipe on the back of the head, E28 535 bottom rad hose, E34 top rad hose, e30 header tank, E28 535 plastic T-peice.
I had to use a reducing straight plastic connector on one of the pipes to the heater to get the right diameter.
BristolBulldog
Post Tue Jan 16, 2007 7:24 pm
Awesome. thats really helpful.
the e28, 535 t piece. thats literally just a cast splitter?
I take it the top hose that doesnt come from the t piece goes to the top of the e30 heater matrix?
i know the heater matrix only flows well in one direction.
DRIFTBOY
Post Tue Jan 16, 2007 7:25 pm
My 335i is E34 based. I also used the E34 radiator, most people use an E28 one but I don't think it makes much difference to the hoses.
As you say, length is the important thing, but with the E30 engine bay being smaller they just need trimming down. It will vary slightly how much depending on which engine position you are using.
I simply shortened my top and bottom radiator hoses and the heater pipes.
As shown below I used the E34 pipe from the thermostat housing but cut and spliced into an E30 325i hose which goes to the expansion tank (later type mounted behind left hand headlamp) and the heater - top pipe on matrix. The join is under the inlet manifold so can't easily be seen, I used a plastic joiner piece that I bought on Ebay advertised as a part for a pond or something!
BristolBulldog
Post Tue Jan 16, 2007 7:35 pm
Thats exactly where i was getting stuck. i finally have it figured (in my head anyway).
once the six gets collected, i will be straight down the local dealer to order the hoses up. I was thinking of new fuel lines as well. anyone know the diameter (internal or external) of the fuel lines? Would make sense after doing so much to replace the lot.
This hose thing is the one thing that stopped me. I figured it out in my head ages ago, but it kind of killed my motivation alot. now this looks so much easier (yep, i managed to do everything else, including fitting the genuine m3 kit but this is what took me off the project for so long).
can't wait to get the new hoses. anywhere as a good source online? getting down bmw is always a pain with me being in work until the weekends.
Andy335Touring
The T is plastic if thats what you mean ?
No, i think the hose that tee's off the top rad hose goes to the bottom connection and the hose that comes of the plastic T goes to the top connection.
I'm 99% sure the above is true, if it's not hammering it down tomorrow afternoon i'll double check.
DRIFTBOY
Post Tue Jan 16, 2007 7:38 pm
Andy335Touring wrote:No, i think the hose that tee's off the top rad hose goes to the bottom connection and the hose that comes of the plastic T goes to the top connection.
That is correct Andy, I've just been and had a look at mine! :D
Andy335Touring
Post Tue Jan 16, 2007 7:39 pm
Try Euro Car Parts or GSF, sorry i've lost the links :o:
BristolBulldog
Post Tue Jan 16, 2007 7:48 pm
Thats excellent thanks alot. It saves so much hassle. Remind me to get you some beers if we ever meet up.
I'm running a standard engine to start with, but i have another engine that has had alot of work done on it. head/cam (288 piper)/skim/port/polishing etc, and i will be fitting the hartge throttle bodies i have as well.
I mentioned 300bhp as a target and got laughed at (well i think its a figure worth trying for!) no idea hw gigh it goes, but the 6 wasnt properly tuned, and that was very good, well above my 325i which had a fair amount of work done to it.
we shall see!
the main point the project will excel at is handling and braking. i have made my own coilovers, and she is running 360mm 6 pot calipers fronts.
Andy335Touring
Post Tue Jan 16, 2007 8:00 pm
Did you get the throttles/adapter plate from a chap called Ian ?
Was the Piper cam the one that was on Ebay a week or two ago ?
I think you'd need to chuck big bucks at an M30 to get to 300bhp and a really lumpy cam that probobly won't pass an MOT because the tick over emissions will be to high ?
Your not going to be to far from there depending on the final spec and tune, circa 270-280bhp ish ?
What were you thinking of using for an ECU and exhaust manifold ?
Sorry, lots of questions but i'm kind of in the same boat as you as mines been fiddled with.
BristolBulldog
in that diagram what aprt numebr is number one?
i have picked up what i think is the right hose: -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
and i am looking at the top hose now.
part number 211110570?
its 38.06 from ecp. soundabout right?
DRIFTBOY
Post Tue Jan 16, 2007 8:08 pm
Sorry bud, I'm sure that's not a hose you need (the Ebay one).
Part number of no.1 in picture is 11531722669 that is for a non air-con model which I had as my donor car. Not sure what differeence is in the hose for air-con.
Andy335Touring
Post Tue Jan 16, 2007 8:13 pm
Not sure about the ebay hose, not sure what model it's for ?
But it looks about the right size and it's got some nice bends which is going to be handy.
These are the numbers for #1 depending on age and transmision type.
£38 sounds about right from ECP.
Whilst your on ebay buy your self a ETK parts catalogue CD, very handy to have.
BristolBulldog
Post Tue Jan 16, 2007 8:16 pm
i had one ages ago. was really disappointed when it didnt have the pricing database file. when i got distracted with tropical fish, and flat conversions i lost the disc! think i should get another!
part number is the bottom one. Same as the one on the picture above. mso many numbers i wasnt totally sure.
BristolBulldog
Post Tue Jan 16, 2007 8:17 pm
http://cgi.ebay.com/ebaymotors/BMW-RADI ... enameZWD2V
yep its the right one. will source one in uk.
Andy335Touring
Post Tue Jan 16, 2007 8:18 pm
DRIFTBOY wrote: Part number of no.1 in picture is 11531722669 that is for a non air-con model which I had as my donor car. Not sure what differeence is in the hose for air-con.
I see where you got that part # from now, national version northern countrys, what ever that means ?
http://img442.imageshack.us/img442/1753/e34bap8.png
Andy335Touring
Post Tue Jan 16, 2007 8:21 pm
BristolBulldog wrote:http://cgi.ebay.com/ebaymotors/BMW-RADI ... enameZWD2V
Yes, same as the top one in this pic posted earlier
DRIFTBOY
Post Tue Jan 16, 2007 8:22 pm
I just assumed England is considered a northern country! :? ???
I could be wrong.
Bristolbulldog - that US Ebay hose is one you need, not sure it's worth buying from America though!!!
Andy335Touring
Post Tue Jan 16, 2007 8:23 pm
I've got the ETK price file if you ever need it ?
Andy335Touring
Post Tue Jan 16, 2007 8:34 pm
I could be wrong.
I'm not too sure either mate, i just use the main numbers and ignore the various national versions, i might be cheaky and ask the parts guy the next time i'm there :)
BristolBulldog
Post Tue Jan 16, 2007 8:54 pm
i want a complete set really. I have contacted him about a complete set minus the one i bought off ebay two minutes ago.
I am looking at braided fuel line now. what bore is that?
http://cgi.ebay.co.uk/5-16-STAINLESS-ST ... dZViewItem
looks good, but they never say if thats the size ID or OD. pain in the butt! what do you wreckon?
DRIFTBOY
Post Tue Jan 16, 2007 9:04 pm
When I replaced mine that go from the under-floor metal pipes to the E34 535i fuel rail I used 5/16" (8mm) hose.
BristolBulldog
Post Tue Jan 16, 2007 9:07 pm
think i'll order a meter of that as well.
can't wait to get her turned over.
Sad thing. I had a friend who used to do stainless work, but he has changed career now, so can't get it done cheap. i need to get the exhaust made up. I will have to start calling around after that now. unless he has a contact i can use. He may be able to still do it. will have to see. don't fancy 800 for a fritz bitz one really!
gareth
Post Tue Jan 16, 2007 9:52 pm
i missed this post as i've been away from here for a few days, sorting my PC out...
if you use a E28 535i radiator (thinner for a bit more room up front) then you'll need a E28 535i bottom hose. this needs no modification.
if you need a top rad hose, check the priced for E32 and E34 ones. they're a bit different at the rear but this is cut off and iirc one is about a fiver cheaper! :D
i am actually using a bit of E30 heater hose on the rear of both hoses to the matrix as this fitted around the servo a bit better. it's a squeeze though. essentially, the fronts of the hoses are E32/4, the rears are E30. this does mean i connected the heater matrix up backwards though and it makes an odd knocking noise when you do this which took a while and some help on here (mr andy iirc :D ) to find! i thought it was a insane relay :D
oh, buy some KY jelly for getting the top hoes on the rad as it's quite a stetch! winkeye winkeye
if it helps, there are a load of (random!) pics from my conversion that may be of interest/use to you on here:
http://smg.photobucket.com/albums/v382/ ... ?start=all
Toby_Unna
Boost Junkie
Post Tue Jan 16, 2007 9:56 pm
i think i had a look around the 335itc site ages ago... you were going to turbo it if i remember?
BristolBulldog
Thanks. i'm just ghoing through all the awqward stuff, that deters me from getting on and finishing it.
Next up is getting all six guages to work. (was orighinally going to be turbo).
i need to find out all the threads, and sizes, so i can get the vacume, oil temp, pressure, etc etc going.
going top be a nightmare. doesnt anyone do a "size" checker kit. so you can thread it in and get the size?
BristolBulldog
Post Tue Jan 16, 2007 9:58 pm
i'm going to sign up to that photbucket thingy temporarily and get some picks up. want them in this post or a seperate one? general pics of the car and the wierd work thats been done.
gareth
Post Tue Jan 16, 2007 10:06 pm
bunging a link to your photobucket album on here will save loading time but it would be cool to see some piccies :D
