Bmw 325i Sport 1987
gt3
Sat Jan 13, 2007 8:18 pm
Hi
My bmw 325i is overheating. So i replaced the thermostat and i bleed out the system. The problem is still there. I have noticed that the fan on the radiator does not come on.
Does anybody know what the problem can be.
E30Adam
Sat Jan 13, 2007 8:21 pm
gt3 wrote: My bmw 325i is overheating
gt3 wrote: I have noticed that the fan on the radiator does not come on.
I think you answered your own question.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
e30bmlover
Ac Schnitzer prophet
new viscous fan it is then mate! are you loseing any coolant? is there a type of mayonnaise stuff when you undo the oil cap?
Sat Jan 13, 2007 8:26 pm
gt3 wrote:. I have noticed that the fan on the radiator does not come on.
Only relevant if the overheating occurs when stopped or moving slowly. If the overheating occurs at "normal" driving speeds then there is another problem.
johnna
E30Zone Irregular
Sat Jan 13, 2007 10:11 pm
Air lock, silted rad/ tubes, dodgy replacement stat (use BMW- it DOES happen), hgf...
Check these: does the top hose get hot, as well as the bottom hose when you run the car from cold?
When you refilled with coolant, was the heater on hot?
Some systems can be hard to bleed, I usually fill up to the set level, then force the coolant through by putting a Halfords flexi coolant tube snuggly in the rad filler neck and blowing the coolant through. Best to do this cold...
I await the big puff or blow job jokes...
Be a man for once in your life and sh!t in that boot!- Wilfred.
Sat Jan 13, 2007 10:39 pm
johnna wrote:putting a Halfords flexi coolant tube snuggly in the rad filler neck and blowing the coolant through. Best to do this cold...
As ever, BMW already fit all that is needed to do this, on 6 pots, at least!! Pull the overflow pipe back through the hole in the inner wing, put the free end in your mouth, a hand flat across the filler neck, and blow.
johnna
E30Zone Irregular
Sat Jan 13, 2007 11:23 pm
Well I never!
It's my old e36 trick to use the flexi pipe...
... damn those Bavarian Boffins!
mrLEE30
Sun Jan 14, 2007 3:34 pm
when he says the fan is not coming on he may mean the electric auxiliary fan, and not the viscous fan, if the viscous fan is not coming on then he does have problems!!
that leccy fan will only come on when the A/C is on or the car is very hot indeed
but as said both fans will only affect startionary situation.
mrlee
gt3
Sun Jan 14, 2007 9:58 pm
hi guys thanks for all ur advice and tips had a good look around the fan that is next to the radieater today and found out why it was not working, the fan blades were geting stuck with the plastic cover around the fan. :)
Sun Jan 14, 2007 9:59 pm
Check your engine mounts.
