As if it isn't low enough on power already...
Davenotouring
Post Mon Jan 08, 2007 11:42 pm
My 316i has this 'issue'.........
When on part throttle, accelerating from a junction, it doesn't accelerate smoothly. It doesn't 'jerk' (like me), it accelerates, then drops slightly, then back to normal, then holds back again, then goes, then holds back. Alternating every second or so.
On full throttle, it's fine.
You can see the MPG meter moving down slightly, then back, then down then back, in synchronisation with the feeling of holding back.
I was thinking possible O2 sensor?
Any other ideas? It's fu**ing annoying. :)
BMW 328i Cab - Daily Slag
g57yle
Boost Junkie
Post Tue Jan 09, 2007 12:37 pm
I think you would get a much better responce in the technical menu.
Hope you get it sorted
Davenotouring
Post Tue Jan 09, 2007 1:37 pm
Cheers mate,
But it's not an E30!
I'll wait and then pretend I've done an engine transplant into an E30! You ain't seen me, right! :wink:
Splondike
Post Tue Jan 09, 2007 1:54 pm
:lol:
You mean you use less than full throttle sometimes Dave :wink:
Mark.
Davenotouring
Post Tue Jan 09, 2007 2:10 pm
Rarely Mark, but I want economy when I don't use full throttle! :wink:
Splondike
Post Tue Jan 09, 2007 2:18 pm
fair enough :D Sorry I can't help with the problem old chap
Mark.
Davenotouring
Post Tue Jan 09, 2007 3:01 pm
Heh!
No problem Mark.
My guess of oxygen sensor makes slight sense, because the way I understand it, at wide open throttle, the values are taken out of the equation, and on part throttle it could be measuring rich/lean rich/lean and playing with the mixture causing the hesitation.
Or AFM/MAF possibly. Arrrgg!
Still linked drifts on smallish wet roundabouts, videos to follow. :eek: :)
Theo
Post Tue Jan 09, 2007 4:08 pm
Dave, the hamster-wheel bearing probably just needs changing?!
Davenotouring
Post Tue Jan 09, 2007 4:19 pm
That's possible too.
It's coming up to a rubber band change too.
Theo
Post Tue Jan 09, 2007 4:32 pm
Ahh yes, the dreaded m43 rubber band change. Make sure you get the right stretchification!
Davenotouring
Post Tue Jan 09, 2007 5:31 pm
Pacerpete tells me I can get an industrial strength one for an extra 23bhp. Taking it to 26bhp.
Theo
Post Tue Jan 09, 2007 5:39 pm
I would tread carefully with those. They are actually designed for dual overhead hamster engines, and will cause increased fatigue on most single hamster units.
HTH
d6dph
Post Tue Jan 09, 2007 5:51 pm
Don't forget the resistor on the interior light delay to release a mighty 0.4hp.
I thought all you E36 owners had done this by now :roll:
Theo
Post Tue Jan 09, 2007 5:57 pm
d6dph wrote:Don't forget the resistor on the interior light delay to release a mighty 0.4hp.
Sorry, but if you are not going to take this seriously, don't coment at all!!
:skip:
d6dph
Post Tue Jan 09, 2007 6:49 pm
I do appologise Theo. :D
Post Tue Jan 09, 2007 7:16 pm
:skip:
:lol:
Dave have you talked about it down the pub yet for those extra magical 20bhp's?
Have you checked plugs?
Chris-W
Post Tue Jan 09, 2007 8:34 pm
Jhonno wrote: Dave have you talked about it down the pub yet for those extra magical 20bhp's?
LOL!
Check the leads - I have an E36 318i doing just this, had a duff lead.
m-dtech
Unapproved Trader caution
Post Wed Jan 10, 2007 6:31 am
these have ignition coils or a dizzy?
my m40 had dodgy rotor and it did similar
Davenotouring
Post Wed Jan 10, 2007 9:52 am
Coil on this one.
It's an M43! :D :?
dan_emaps
Post Wed Jan 10, 2007 1:08 pm
sounds like a maf issue to me dude... has it just started doing this out of the blue or has it been slowly getting more and more hesitant?
Davenotouring
Post Wed Jan 10, 2007 1:12 pm
It does it occasionally, sometimes worse than others. Identical symptoms.
Sometimes it's perfect.
Geeman
Post Wed Jan 10, 2007 1:25 pm
It's coz it's a E Dirty Sex... it likes a bit of rough every now and again. :wink:
No idea what it is. Worth trying the leads though, like Chris says.
Davenotouring
Post Wed Jan 10, 2007 1:37 pm
If I 'try' leads and MAF I'll be about £300 down!
Will do at some point.
For now though, a stupid respray on the Civic is top priority!
Karan
Post Wed Jan 10, 2007 2:02 pm
matt black it! with brigt red bonnet
Davenotouring
Post Wed Jan 10, 2007 2:54 pm
It's funnier than that mate! You'll see at Snett! :cool: :eek: :D
dan_emaps
Post Thu Jan 11, 2007 12:43 pm
i've known of identical symtoms on albeit larger engined e36s (323 and 328) which have turned out to be the maf.. but as you said not cheap!! if you know anyone unfortunate enough to also own a e36 316 :wink: then maybe you could 'borrow' theirs!
Andyboy
Alpina Colada
Post Thu Jan 11, 2007 1:58 pm
Dave - if U need a MAF bell me. There are a few damaged 1994-5 316i/318i's in my local breakers. Could get one and send it.
Davenotouring
Post Thu Jan 11, 2007 4:07 pm
Andy,
No rush, but if you could grab one and send it that'd be great. At least to elimate it!
Andyboy
Alpina Colada
Post Fri Jan 12, 2007 12:40 am
What's the VIN number?? Need the last 7 Dudeski.
Davenotouring
Post Fri Jan 12, 2007 8:56 am
Buggggggggggger.
I'll get it fooorreee ya.
Andyboy
Alpina Colada
Post Fri Jan 12, 2007 11:08 am
Also need the part number on the air flow meter itself! There are two types on the 316i. It IS a 316i, isn't it?? :?:
Davenotouring
Post Fri Jan 12, 2007 11:12 am
I'm pleased to say it is. It is also a beauty!
