M50 pistons in M20 for 2.7 conversion?
jr79
Post Sat Jan 06, 2007 8:17 pm
Hi
I`m building together a M20 325i engine (early model), and are looking for more power. I have purchased a 324td crank. The plan is a high-comp (10-10:5) 2.7 engine with 325 head (885).
As I have read there are several ways to do this. I`m thinking that the best way would be not to shave of the block. After studying a piston catalog I found out that the M50b25 piston together with 130mm conrods from an M20b20 could be just perfect. (Maybe with small modifications on the pistons.)
The M50b25 piston is flat at the top. This will of course affect the volum of the combustion chamber. This I can calculate, but how will a flat piston affect the engine in other ways? Have anyone done this?
Or what other pistons can I use? Late/early eta pistons maybe? (This engines was using the 731 head, so its hard to calculate what the comp will be when fitting a 885 head.)
best
Jon
Post Sat Jan 06, 2007 8:21 pm
Valve/piston contact
Better off buying custom pistons really
jr79
Post Sun Jan 07, 2007 7:48 pm
Teah, but those pistons are hard to find. Will the shape of the piston affect the engines drivability? I mean, the m20 engine comes with many different piston shapes.
Templ8e30
Post Sun Jan 07, 2007 9:03 pm
The valve pockets will be mis-matched surely ? 12v head with 24v pistons ?
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Post Sun Jan 07, 2007 9:10 pm
jr79 wrote:The M50b25 piston is flat at the top.
Not completley flat, they still have valve pockets like Iain is refering to
jr79
Post Sun Jan 07, 2007 9:11 pm
There won`t be any valve pockets.. As long as the valves don`t crash with the piston, will it matter?
Post Sun Jan 07, 2007 9:19 pm
So your going to machine the tops of the pistons?
Loads of engines run flat pistons so I dont see why it would cause a problem.
Turbo-Brown
Boost Junkie
Post Sun Jan 07, 2007 9:35 pm
Be interesting to know exactly what the features on the M20B25 pistons are for before assuming they can be removed.
jr79
Post Mon Jan 08, 2007 7:33 am
"Be interesting to know exactly what the features on the M20B25 pistons are for before assuming they can be removed."
Yeah, thats exactly what I`m trying to find out.
The M50 pistons will be allmost flat because I have to shave the top a little. The reason why I found the M50 piston interesting is because of the flat top, allmost perfect comp height, and short total height. (With this I can use the original 135mm conrods)
