Changing Steering Wheel
iDreamBeemer
Post Fri Dec 29, 2006 11:27 am
Well, broke my ebay cherry and managed to buy a tech2 wheel and pretty pleased.... here is a poor pic!
Going to replace the tech1 wheel on just now....
Am I right in thinking you need to take the badge off with something like a screw driver to get to the bolt behind or is there more to it?
Templ8e30
Post Fri Dec 29, 2006 11:36 am
Iirc the whole centre section pulls off (horn push).
See here: http://www.realoem.com/bmw/showparts.do ... g=32&fg=35
Remember you'll need the key in the ignition turned to position 1 with the steering lock off or you won't be able to remove the old wheel.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
gooner1
Out humping Reindeer
Post Fri Dec 29, 2006 11:44 am
And watch your nose when you pull wheel off mate.
iDreamBeemer
Post Fri Dec 29, 2006 11:52 am
sorry, not clear enough! Its the tech1 wheel I wanted to know about, I can see easily enough on the new wheel!
Gortour
Post Fri Dec 29, 2006 11:56 am
I THINK the Tech one just removes the BMW badge from the centre as you first suggested.
OBs
Post Fri Dec 29, 2006 12:19 pm
Dreamer you selling your Tech 1 wheel mate is it a little one??
Dan318-is
Post Fri Dec 29, 2006 12:22 pm
Correct me if im wrong but i think that looks liek an e36 tec 2 wheel? the centre holds aim up at an angle rather than straight across liek the e30 ones?
on tec 1s the roundel pops of to expose the 22mm nut, on tec 2s the whole horn push assembly simply pushes off to expose it,
iDreamBeemer
Post Fri Dec 29, 2006 12:39 pm
Dan - pretty sure its an e30 one - I measured it this morning and it is the 370mm smaller version. I understand the e36 were 385mm...
They are the same size I think for tech 1s but no, not selling, I plan to be able to put the car back to original spec if I want to sell it so it is destined for the garden shed!
Dan318-is
Post Fri Dec 29, 2006 12:40 pm
only one way to find out mate! should only take five minutes to refit a new one go n give it a try!
OBs
Post Fri Dec 29, 2006 12:42 pm
Bugger!
Templ8e30
Post Fri Dec 29, 2006 12:57 pm
Yes sorry, the tech one requires the centre badge to be prised out with a small screwdriver :mad:
Cheers,
Iain T
iDreamBeemer
Post Sat Dec 30, 2006 10:32 am
OK, the nut I can get too but not sure on what to do next - do I need the keys turned to position 1 to undo the nut? If so how the hell do you stop the steering wheel from turning?
spent a few minutes trying both ways and the nut wont budge (having been there for 16 years I can understand) any advices folks?
eko
Old timer
Post Sat Dec 30, 2006 10:37 am
iDreamBeemer wrote:OK, the nut I can get too but not sure on what to do next - do I need the keys turned to position 1 to undo the nut? If so how the hell do you stop the steering wheel from turning?
Martin,put the steering lock on(key removed) then loosen the nut,then insert key and turn to position 1 to remove the wheel!
Post Sat Dec 30, 2006 10:41 am
Put the nut back on a few turns before you pull at the wheel. Saves a visit to A & E at a time of year when they are short staffed.
iDreamBeemer
Post Sat Dec 30, 2006 10:44 am
cheers Brian and Tony, now all I need is some arm strength!! No long poles in the house!
Can I put wd40 on to try to loosen it a bit?
p.s. Tony have you sold your short shifter?
DaveD
E30Zone Wiki Specialist
soak the nut in wd 40 ,,with the steering lock off get someone to hold the wheel while you turn the wrench anti clockwise or keep tapping it with a hammer (the wrench) while trying to turn it....you need 3 hands
best of luck
eko
Old timer
Post Sat Dec 30, 2006 10:51 am
No Martin ive not sold it,its still in my car :roll:
Priced up the 2.8 one recently and its about £35,just had more important things to put that £35 into :?
iDreamBeemer
Post Sat Dec 30, 2006 10:59 am
:wink: no worries Tony, just would hate to think I missed a bargain!! Understand its low on the priority list, got a few other things I have to sort out too (like the fecking paint!!)
just tried again and I think I am going to need some help, need to rope in a second pair of hands or a bigger socket wrench!! Could you use an air gun or is that a bad idea? Its not budging at all!
eko
Old timer
Post Sat Dec 30, 2006 11:03 am
Martin have you tried undoing the nut with the key removed?
Some people might say its risky(putting strain on the column) but ive done loads like that and never had a problem!
Once the nut is `loose` you can insert the key and carry on as described :)
iDreamBeemer
Post Sat Dec 30, 2006 11:08 am
Thats what I was doing, it was the only way I could get resistance to push against but the nut wont budge
eko
Old timer
Post Sat Dec 30, 2006 11:10 am
:mad:
ah right :mad:
What size ratchet are you using then?
You got nothing to hand to slide over the end of the ratchet to extend it?
Piece of tubing/pipe etc?
Post Sat Dec 30, 2006 11:13 am
Can't see WD40 helping much, as it isn't going to be a rust problem. Should be tight (79Nm), but not THAT tight.
Agree with not putting too much strain on the steering lock. Get someone to hold the wheel as well.
iDreamBeemer
Post Sat Dec 30, 2006 11:19 am
quite a short small ratchet, no tubing though, have bashed it a couple of times with a hammer but I dont want to be too rough and damage the rest of the steering!
No rust there at all, but does look like some white paint on it.....?
Will need to find a friend to hold the wheel! but that will have to be a bit later on....might try to see if I can get some tubing or borrow a bigger ratchet and see how I get on.
Post Sat Dec 30, 2006 11:22 am
Ratchet? Ratchets aren't for tightening or loosening fasteners; they're for removing them once they're loose. It's too tight for a ratchet. You need a cracker bar or at least a sliding T bar.
iDreamBeemer
Post Sat Dec 30, 2006 11:23 am
pardon? not got a lot a tools and pretty sure I dont have either of those!!!
benjy
Post Sat Dec 30, 2006 11:28 am
Three Weetabix's mate and dedication thats all you need!! Seriously tho, it just takes a bit of muscule/weight on it. If its never been off then it will be tight and will prob have the remains of thread lock holding on...........
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Gortour
Post Sat Dec 30, 2006 11:33 am
I have a 4-bar wheel brace, very handy for such things. Just needs an end with a 22mm on it.
Also bought one of those extending bars for wheel nuts a while ago for about £3, comes with a reversible 17mm / 19mm head, but it's a standard 1/2" socket end, so a 22mm socket would fit no problem.
iil325i
Post Sat Dec 30, 2006 11:44 am
check the indercaters are terned off when you put the new wheels on as you will brake the bit that turns them off when you turn the wheel, and thats a pain in the ass.
go get a braker bar there only like £10 for a s**t one, then keep it in the car. you can beat chavs with it if they cut you up winkeye
Post Sat Dec 30, 2006 11:55 am
iil325i wrote: go get a braker bar there only like £10 for a s**t one, then keep it in the car. you can beat chavs with it if they cut you up winkeye
One of those extendable wheel nut breaker bars would do, and is a useful addition to any car boot.
The one I acquired has a reversible 1/2" socket on it, that comes off to leave a useful cracker bar.
iil325i
Post Sat Dec 30, 2006 12:05 pm
yer i have one of them as well you can get these for well under s 5er now.
Gortour
Post Sat Dec 30, 2006 12:47 pm
Brianmoooore wrote:One of those extendable wheel nut breaker bars would do, and is a useful addition to any car boot.
Yup, that's the one I have. Very good it is too, and being standard 1/2" it has even more uses. Well worth £3...
