ideal suspension geometry settings and spring rates
gareth
i'm (slowly) sorting out the suspension on my car and the first thing on the cards is a rear end rebuild. i have some BMW rubber offset trailing arm bushes and polyflex rear subframe mounts to fit. lowering is about -40mm
at the front i have polyflex offset control arm bushes and a -50 ish drop (tbc, i'm making some coilovers for it as it's -70 or something stupid at present due to the wrong springs and a fat M30 lump!!)
does anyone have an idea on what toe and camber settings i should be looking for, from a handling point of view? also, is there a guide anywhere on how exactly to set up the offset rear bushes?
regarding the front springs, has anyone had a play with different spring rates or know the standard bmw rates? i can get any rate or length i want for about £30 a pair but i could use a starting point!
gareth
just found some info on eccentric bushes... though they're the k-mak ones.
the data on the graphs will be innacurate if the bmw bushes have a different eccentric offset to the k-mak ones though.
http://e30m3performance.com/tech_articl ... c_bush.htm
DRIFTBOY
Interesting link Gareth!
I wish I'd known about those bushes before I slammed my car on it's belly and fitted my Powerflex non-concentric ones!
Any ideas when your's will be back on the road?
Andy335Touring
Tell me about itDRIFTBOY wrote:Interesting link Gareth!
gareth
oops!!!DRIFTBOY wrote:Interesting link Gareth!
aside from the camber issues (as it's more obvious) you also get toe-in with lowering and with pokey RWD i can see that this could add a fair amount to the instability under power with the rear end trying to squirm about.
as you've just done yours, everything will be nice and easy to remove to do it again!!!! tyen you can pop by and do mine for me too!
mine has so far got absolutely nowhere!!!! i have got some subframe bushes in double quick time from the E30Zone shop (cheers sal!) but with the christmas lergi in full swing i haven't touched a spanner! i've been off work since 15/12/06 too!!!!
hopefully i can get some done before i return to work next tuesday though...
gareth
cheers mate... do you have a link? maybe i'm being stupid but i can't find it!Andy335Touring wrote:have a look on R3V forum for coil over spring ratesgareth wrote:
DRIFTBOY
Squirm about isn't the half of it!!!
Yesterday in the damp it was spinning the rear wheels in 3rd gear at 60+ mph!
If you get stuck - I'm sure a man of your calibre won't though - I'm happy to lend a hand if I'm free of a weekend.
And as you say, at least all my nuts and bolts have been off within the last couple of months so shouldn't be too bad to change if I feel like doing it!
Turbo-Brown
- Boost Junkie
There's a lot of that going about at the momentYesterday in the damp it was spinning the rear wheels in 3rd gear at 60+ mph!
Andy335Touring
gareth
thanks martin, i should be fine, it's just summoning the enthusiasm to get out in the cold!
re wheelspinning, has anyone else noticed it being very very slipper lately? i've been having traction problems in the corrado when it comes on cam in 3rd!!! it's only 140bhp ish too!
oh and thanks for the link andy
DRIFTBOY
No probs - good luck!gareth wrote:thanks martin, i should be fine, it's just summoning the enthusiasm to get out in the cold!![]()
re wheelspinning, has anyone else noticed it being very very slippery lately?
And yes, I've noticed the slipperyness - great isn't it!
gareth
if the rear wheels are doing the steering then it is good! if not, then it isn't!!!
Andy335Touring
Yep, i've got some Avon's on the front that arn't the best tyresgareth wrote:if the rear wheels are doing the steering then it is good! if not, then it isn't!!!
might stick em on the back and see if i can wear them out quicker !
gareth
i do that! if i don't like tyres i put them on the back (or front on a FWD wrongnessmobile) to kill them off!
Andy335Touring
I was keeping my Goodyears on the back to be safer in the wet(high speed over steer
) but i just want to kill these Avons
gareth
i finished my (by then borderline illegal) toyo rears off at the pod rather nicely!!! loads of rubber splattered up the rear quarters!!!!
incidentally, i've still got my number on the rear window!!!
Andy335Touring
DRIFTBOY
I might be up for some RWYB Pod action end of january or mid february, I have looked up all the dates. Need to get mine down the strip!
What tyre size do you use Gareth? Ive got the same wheels as you and have worn my 225/45/16 rears out quicker than expected. (inside edges) Considering some 205/45's same as the front, what do you reckon?
gareth
i'm running 215/40/16 toyo proxes
cost me about £160 for the set on here a while ago but they're a bit more now
http://ssl.delti.com/mytires/Tyres.html
40's
My gearing is high enough as it is
According to the tyre calculator I would lose over an inch in diameter and about 3mph
Ive been thinking of 50's for some tight arse mpg saving motorway miles,
You got those bloody cheap! Im being quoted nearly twice that for them in my size. They still dont beat my local discount tyre place though
gareth
they were on offer but still bloody cheap! it's a nice cheap size, handles well but does drop the rolling diameter a bit but i like this and it suits the car well
with my smaller tyres and 3.91 diff, economy is interesting! i must find a taller diff at some point!
