as above
contact no 07813 002571
location beckenham
cheers.
who wants to fit a head gasket for me on my 6 pot
ajm-e30
to far for me to come
seanboy
just a bit
eltel
tackle it yourself..i did and was a sinch!!! just take your time and make sure you get the head skimmed!!!
take a piece off one by one and mark them with tip ex if necessary
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
jcjdavis1
Hi everything is easy when you know how,I have been taking bits off mine but have come to a halt as I see things that scare meeltel wrote:tackle it yourself..i did and was a sinch!!! just take your time and make sure you get the head skimmed!!!
gooner1
- Out humping Reindeer
Sorry to butt in but im planning to try a top end rebuild myself soon which i assume means replacing the head gasketbut why would you have to have the head skimmed ?. Or is it only if your head gasket has blown,also im pretty sure that ive seen on here that its better to have metal added to head rather than have it taken off,or am i getting mixed up with something else(as per). Thanks,
aauser
Head usually needs skimming if the head gskt failed due to overheating etc. It's in case the head is warped and to make sure that the whole job is not just a waste of time as you could still be left with a leaking head gskt if you didn't have your head skimmed.
Skimming the head does increase the compression ratio a little but thicker head gskts are available for some vehicles (not sure about BMW) to compensate for this.
if you're just doing a strip & rebuild, skimming is NOT strictly neccesary, as long as you have the head checked and pressure tested. However, having said that, if you are going to the expense of doing a strip/rebuild, skimming would definately be a good idea.
HTH, Ray
HTH, Ray
gooner1
Thanks for that Ray, if the head is checked and pressure tested what is the advantage of having it skimmed?.
Apologies for my densness but im no mechanic but you gotta have a hobby havent you.
dips346
- London Meets Main Man
pm nelly he can help you out
aauser
The advantage of getting it skimmed is that you get a nice smooth and 100% flat surface on the underneath of the head where it sits onto the head gskt and cyl block so you know that you'll have a good seal.
But, as I said, this will slightly increase the compression ratio (depending on how much is skimmed off) which could be a problem, depending on what you're doing with the engine, with regards to tuning etc.
As aauser's reply - to get a nice smooth, flat surface. There are a couple of shallow holes on the head face which, when skimmed to the bottom of these holes, is the absolute limit.
