Can any one tell me whats the best way to fit the mtech2 kit on my cab i know bits of the kit need to be cut and bumper mounts need to be swapped does anyone know exactly which ones?
All the help and info would be appriciated as im starting to fit the kit from tomorrow.
MTECH2 KIT ON A CHROME BUMPER CAB
e30-unit-soldier
kevin316i
The original motorsport convertibles had a type 2 MTEC bodykit which was fitted to the chrome bumpered body type. If you got one of these it should fit perfectly. I guess the MTEC kit you have came off a plastic bumpered car such as a 325i sport.
Suggest you have a look at the ETK for the MTEC bodykit as fitted to the original motorsport convertibles and cross check its fitting against the ones specified for the MTEC bodykit as fitted to the 325i sport.
iil325i
the fogs are not the same you need the big fogs and front lower part
Richy325iTouring
you will need the lower ront valance from a face lift car
the bumper brackets front and rear
the the kit will fit but the rear bumper will have a gap at th back because the arches are different
your best bet get a fberglass copy for the rear so it doesnt matter if you butcher it
try and get the gen stuff for the front
its easy ive done it in the past
