as above going to do a swop next week ive pulled them out the top before
but never from the bottom (oooh) i have removed the subframe before. is there anything i have to watch out for or tips ie wheels on or off or leave it all on a jack or should i support the engine and box seperately...it seems easier as i want to swop the suspension at the same time and i dont have to change springs/power steerring pipes(its going into a 318)
also when its out is it easy to move around so i can gunk it all down and give it a lick of paint to tidy it up (nice misty buff i think)
dropping an engine out
gazza
mybmw6
I took my 325i engine out from underneath. For me and the tools I had it worked out easier. I removed my wheels (much easier to do while on the car rather than later), but left the engine on the subframe. The guy helping me made up some brackets to fit on the shock mounts and we lifted the car using a chain hoist and dropped the engine onto a welded up rolling frame.
Before the engine came out I removed the exhaust from Manifold down, disconnected the driveshaft, removed all the ancillaries p/s a/c etc and left them on the car along with the loom. I was putting in a new camshaft and fixing some steering rack and gearbox issues, the engine was coming out and going back in. I left the gearbox attached to the engine.
Hope this is of some helps.
Matt
Matt
A small frame on castor wheels is best, like the type bread vans use
Wheels off, dissconnect brake lines from calipers, abs etc, exhaust frontpipe, prop, gearbox mount, pull ecu harness through and dissconnect loom in the usual way, dissconnect steering UJ from rack, remove strut top mounting nuts and subframe mounting bolts then jack the car over the engine and slide out from underneath or if the car is scrap then cut the front panel and cross member out which will make the job oh so much easier
gazza
cheers so would you support the engine and lift the body off the subframe and drop the next body straight on top and bolt up the bits
Yep, thats how I always do it
seanboy
Just wondering,If you had an engine crane would you be able to just lift the engine and gearbox out or is there more to it. got to go underneath the car, pulling car over engine while supporting the engine or taking off front of car if its scrap all good ways but wondering about the crane. get cheap discount at hss and not putting anything back in. cheers
Ive got a crane, its just a pain with 6 pots and if the suspension is coming off to be changed over then why bother with the crane
gazza
dan how would you lift the body ....jack on each chassis member or jack and beam of wood sounds like i need a few jacks but if i support the engine on blocks maybe it would be easier
Heres a pic of the 4 pot coming out of mine
I think I had a piece of 4x2 accross the 2 jacks but cant really remember.
gazza
right sorted one last question when re fitting does the body come down to the floor and you bolt up the struts and lift the lump up and allign all the bolts and bits
Yes, you will need to have something underneath the lump, on castors is best so you can move it about.
