fog light bulb replacement
spence_star
Post Sun Dec 24, 2006 3:27 pm
zoners, any idea on taking out a fog light bulb?
the furthest i got was disconnecting the socket from the back of the light, but then i got stuck.
Advice please with pictures would also be helpful
Thanks Zoners
gazza
Post Sun Dec 24, 2006 4:14 pm
if you have the cover removed ...thats the one held by 2 screws then you only have a wire clip to move before the bulb will come out (its on a piece of wire connected to a spade connector)...dont touch the bulb glass and refit is the reverse its easy really as you will find once you have done it
spence_star
Post Sun Dec 24, 2006 7:03 pm
ah ok i think i saw 2 screws when i looked under the bumper, the 2 screws are facing down right? I mean the philips head are visible as they face down towards the road.
Are they the 2 screws your talking about. Its jus so bloddy hard getting under the car because its soooo freakkkkkin low.
Returned after many years out.
Gortour
Post Sun Dec 24, 2006 7:06 pm
I've got the later E30 fogs, only one screw in each of mine, and they're underneath the light, as you say, screw heads facing the road. Undo the screw and then rotate. (On mine, anyway...)
Post Sun Dec 24, 2006 8:10 pm
There's a hard way and an easy way of doing most things!
The easy way is to remove the little plastic plug half way down one side of the front glass and unscrew the self tapper behind it. The whole light will then come out from the car through the front, and you can unscrew the two screws for the plate and change the bulb with ease.
