Kerbing repairs
nolc
Post Mon Dec 18, 2006 6:18 pm
sdfghhjkllllllllllllllllllllllllllllll
thebigone
Post Mon Dec 18, 2006 6:43 pm
I have used in the past, a metal filler that you can get from a hobby shop, it is used on railway track connections a bit like liqued metal you are able to mould it then sand it down hth
325bhpbruiser
Post Mon Dec 18, 2006 6:46 pm
try quick steel mate, under a tenner a tube, dries rock hard you can drill and screw into it and also sandable.
only tip i can gan give i mix the to dough's as best as you can before it starts to set.
mattresstester
Post Thu Dec 28, 2006 3:29 pm
325bhpbruiser wrote:try quick steel mate, under a tenner a tube, dries rock hard you can drill and screw into it and also sandable.
Quick question: once it's set, how does it look? Matt? Shiny?
Cheers.
iil325i
Post Thu Dec 28, 2006 3:32 pm
if there not to bad you can sand them ou twith 240 grit
325bhpbruiser
Post Thu Dec 28, 2006 10:47 pm
half and half really mattrestester.
