Another 10 min job stretching into days...
Took all bolts off thermostat housing - 2 bolt heads sheared off and stuck in the head/block.
The question is, I'm not sure I have enough room to use a tap+dye set without removing the head/engine? The offending area is facing the radioator with maybe 10 inches max if space.
I'm replacing the engine in Jan/Feb anyway so should I just put as many bolts back on as I can with a load of gasket seal and see if it makes it?
The other thing is, I noticed 2 of the distirbutor cap housing bolts have sheared too - they are odd looking long bolts with only a couple mm's of thread at the very end. BMW can't seem to find these bolts with what looks like the correct part number or even when they check the microfilm archive against a sketch from me.
I 'think' I need the bolts that go in the highlighted:
Also (not sure) is the highlited area below the distributor cap housing and it's mounting bolt (item 21)?
Am I reading these diagramns wrong? Are this correct?
Both these problems are keeping the car off the road and it sucks...
As always, much appreciated.
