whats happening here then????
noney82
Post Sun Dec 17, 2006 4:17 pm
any ideas anyone
Cloggy Saint
Post Sun Dec 17, 2006 4:20 pm
vacuum leak? knackered icv?
fuzzy
He who sleeps with "Gingers"
Post Sun Dec 17, 2006 4:33 pm
you didnt fit that ebay wonder resistor did you?
noney82
Post Sun Dec 17, 2006 5:42 pm
fuzzy wrote:you didnt fit that ebay wonder resistor did you?
lol no fuzzy it did it last night but after a while it cleared
Richy325iTouring
Post Sun Dec 17, 2006 6:09 pm
icv
intake boot
vacum leak
Chris-W
Post Sun Dec 17, 2006 6:11 pm
Vacuum leak - probably not intake boot.
noney82
Post Sun Dec 17, 2006 6:12 pm
i'll have to clean ivc and throttle bodies out i think to. hope you like my pet chicken
lol
noney82
Post Sun Dec 17, 2006 6:13 pm
i put my hand over the intake just before the filter and the engine nearly cuts out, where the vacum side of things???
Royalratch
Post Sun Dec 17, 2006 8:45 pm
You missing the air flow guide boot from the front passenger side grille?
Sounds like it's choking...
jmc330i
Post Sun Dec 17, 2006 9:48 pm
Royalratch wrote:You missing the air flow guide boot from the front passenger side grille?
You mean the bit that goes between the airbox and back of the headlight?
Mine doesnt have this fitted at all and is running fine.
James
'91 325i Sport
'93 318i touring 16v
Templ8e30
Post Sun Dec 17, 2006 10:52 pm
I would have thought that a vac leak woul give a constant engine speed.
I had a knackered idle control valve with the exact symptoms, it would also cut out after 30 seconds or so and wouldn't restart unless the ICV was disconnected. Second hand ICV sorted it.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Royalratch
Post Mon Dec 18, 2006 9:44 am
Had a split intake boot (AFM to Throttle) that was leaking air and caused crazy erratic idle. Once revved it was a bit better.
Replaced it and it's fine. They also have a hole underneath that needs to be plugged and the new boot does not come with it so use the old one.
noney82
Post Mon Dec 18, 2006 6:12 pm
can someone send me a pic of the icv just so i know i looking at the right thing. The thing that worried me was as you can see on the video the mpg gauge reving up to arond 50 but when you rev ya car normal to the same revs the mpg gauge doesnt go that far
Templ8e30
Post Mon Dec 18, 2006 6:24 pm
noney82
Post Mon Dec 18, 2006 7:01 pm
ahhhhh cheers iain i was right, to clean it out is just a case of spray some cleaner down it??
Templ8e30
Post Tue Dec 19, 2006 3:05 pm
Yup, that'll clean it.
However it may be bolloxed. Turn the ignition on but don't start her up, listen to the ICV, it should buzz.
If it doesn't then its likely to be knackered.
Cheers,
Iain T
chinchilla
Post Tue Dec 19, 2006 3:28 pm
aww look at the likkle chicken!
