whats happening here then????
noney82
any ideas anyone
Cloggy Saint
fuzzy
you didnt fit that ebay wonder resistor did you?
noney82
lol no fuzzy it did it last night but after a while it clearedfuzzy wrote:you didnt fit that ebay wonder resistor did you?
Richy325iTouring
icv
intake boot
vacum leak
intake boot
vacum leak
Chris-W
noney82
i'll have to clean ivc and throttle bodies out i think to. hope you like my pet chicken
lol
lol
noney82
i put my hand over the intake just before the filter and the engine nearly cuts out, where the vacum side of things???
Royalratch
You missing the air flow guide boot from the front passenger side grille?
Sounds like it's choking...
jmc330i
You mean the bit that goes between the airbox and back of the headlight?Royalratch wrote:You missing the air flow guide boot from the front passenger side grille?
Mine doesnt have this fitted at all and is running fine.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Templ8e30
I would have thought that a vac leak woul give a constant engine speed.
I had a knackered idle control valve with the exact symptoms, it would also cut out after 30 seconds or so and wouldn't restart unless the ICV was disconnected. Second hand ICV sorted it.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Royalratch
Had a split intake boot (AFM to Throttle) that was leaking air and caused crazy erratic idle. Once revved it was a bit better.
Replaced it and it's fine. They also have a hole underneath that needs to be plugged and the new boot does not come with it so use the old one.
noney82
can someone send me a pic of the icv just so i know i looking at the right thing. The thing that worried me was as you can see on the video the mpg gauge reving up to arond 50 but when you rev ya car normal to the same revs the mpg gauge doesnt go that far
Templ8e30
noney82
ahhhhh cheers iain i was right, to clean it out is just a case of spray some cleaner down it??
Templ8e30
Yup, that'll clean it.
However it may be bolloxed. Turn the ignition on but don't start her up, listen to the ICV, it should buzz.
If it doesn't then its likely to be knackered.
Cheers,
Iain T
Cheers,
Iain T
chinchilla
aww look at the likkle chicken!
