I have the chance of an 1992 M50 engine from an E34
Is this the non-vanos one ?
M
M50 non Vanos ??
irish320i
probaly a single vanos engine i think
kam-325i
the M50TU is the one with Vanos.
eko
- Old timer
Could be nonvanos?
The M50 in my car came from a 92 and is non vanos,also got another 92 E34 here which is non vanos!
jmc330i
I think the Vanos engines (TU) are from 93 on, so its most likely a non Vanos.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Ive got a 92 525 and its non vanos
Jimbob
Is Vanos an added issue when putting it in an E30 opposed to a non-Vanos unit? (regardless of faults!)
No difference at all as regards fitting it - but it makes a real difference to the performance!Jimbob wrote:Is Vanos an added issue when putting it in an E30 opposed to a non-Vanos unit? (regardless of faults!)
Jimbob
Really!
There's a cheap 5 series on ebay at the mo with FSH, but it's a 1994 so I guess that's a vanos unit.
Just went round to nextdoor and they known a bloke with a J-plate with a blown autobox, they're not sure if it's M50 or not though.
Jimbob
Another quick question Brian, what flywheel/gearbox/prop/diff combination are you using?
I've read that with about 7mm off the M20 flywheel will allow it to fit to the newer 2.5 block, I'm guessing the same goes for the 2.8 block? Then it would just be a case of finding a 3.64 LSD or similar.
Diff is ex. 525e. (Got the 2.7 bottom end as well, for a future project)Jimbob wrote:Another quick question Brian, what flywheel/gearbox/prop/diff combination are you using?
Flywheel and gearbox are from a non vanos E36 320 that was lying around, and prop is a standard E30 325 one, just about closed up as far as it will go.
m-dtech
- Unapproved Trader caution
vanos unit presents a problem when turbo charging and using megasquirt.
