which way is better to make a 2.7
DJ_B4L
Post Fri Dec 15, 2006 1:27 am
how many ways are there to make a 2.7 and what is the best way?
PIONEER AVIC X1, X1R, X1 BT LATEST SATNAV DISK WITH LATEST MAPS AND ALSO UPDATES FIRMWARE £20 POSTED PM FOR MORE DETAILS
Number plate for sale E30 2 HRD open to serious offers only will suit any E30
**BANNED**
Post Fri Dec 15, 2006 7:29 am
How much do you want to spend?
DJ_B4L
Post Fri Dec 15, 2006 9:32 am
i have a 2.7 already so jus wondering which ways there are to make them and what are the advantages between the two might be interested in making 1 for my cab
Templ8e30
Post Fri Dec 15, 2006 12:11 pm
Best but most expensive way is to use a 525e or diesel crank with late 325i pistons in a 525e/325i block, 320i/323i/525e conrods, 325i head.
The block will need a shave as the pistons will sit too low in the bores.
Vernier pulley will also be required.
The machining for the block is the expensive part.
Easiest and cheapest way is to fit a 325i head onto a standard 525e bottom end.
Both methods use a 325i inlet manifold/injectors/afm etc
Cheers,
Iain T
2007 Mazda 6 2.0 estate
oze30
Post Fri Dec 15, 2006 3:59 pm
Templ8e30 wrote:Best but most expensive way is to use a 525e or diesel crank with late 325i pistons in a 525e/325i block, 320i/323i/525e conrods, 325i head.
Cheers,
Iain T
I have all these parts for sale br vernier pully. Was going to 2.7 mine, but going another way now.. as it turned out to be too expensive for me considering i lost my job!
DJ_B4L
Post Fri Dec 15, 2006 4:31 pm
isnt there a way to do it with a 320i head?
oze30
Post Fri Dec 15, 2006 4:46 pm
yeah.. but its still restrictive. best is to go for a minimum, eta bottom end and 325 head inlet/exhaust manifolds.
Cheaper option is stick the 320 head on it, it's still torquey, but not as free breathing as a 2.5
Expensive option is to:
eta crank,
eta rods,
early 2.5 pistons with the skirts machined to clear the crank webs,
2.5 head/inlet/exhaust manifold (or a 6 branch)
Vernier pulley and BBTB...
And that's close to if not on 200bhp with heaps of torque!
**BANNED**
Post Fri Dec 15, 2006 11:23 pm
My 2.7 is very basic,325 block;eta crank rods and pistons with new rings and a 320 head.Not yet run in but is real hooligan stuff.This afternoon I have been down to the Broads to check my boat out,2 hours each way,Friday traffic,no motorway,not above 3500rpm,258miles.The ability to pass traffic is awesome,what tuned ones with lumpy cams like temple30 and others use must be fantastic.I thought that new front discs and green stuff pads would be enough to control it but I am not so certain any more!!
Ant
Retired Team Member
Retired Team Member
Post Sat Dec 16, 2006 11:51 am
Bal, I'll have 2 freshly built 2.7 blocks in the unit as of Thursday next week, feel free to pop down for a gander mate, they are both hybrids bulit for different purposes
up to you fella !
