There's an adjustment somewhere. Had one like this a few years ago, adjusted it, and ever after it gained a couple of minutes instead.
Replaced the clock with an OBC before I got around to adjusting it again.
You could try fitting a new quartz crystal in it (32.768kHz, as used in most watches/clocks), or it may have a sticky mechanism caused by dust/or be in need of jeweller's oil on its cogs.
ECU Upgrade EPROM Chips, £40 posted within the UK. Note these are not Zone chips. viewtopic.php?f=6&t=279421
