Slow dash clock
Post Fri Dec 15, 2006 9:13 pm
Why does my clock keep slowing down?
Takes about a month to lose 2 or 3 mins :?
No E30 ive had before has done this
kam-325i
Post Fri Dec 15, 2006 9:14 pm
Is it the Analog one ?
Post Fri Dec 15, 2006 9:26 pm
Yes its analogue
Post Fri Dec 15, 2006 10:19 pm
There's an adjustment somewhere. Had one like this a few years ago, adjusted it, and ever after it gained a couple of minutes instead.
Replaced the clock with an OBC before I got around to adjusting it again.
Post Fri Dec 15, 2006 10:23 pm
Thanks Brian, clock out job then
Post Fri Dec 15, 2006 10:27 pm
You could try fitting a new quartz crystal in it (32.768kHz, as used in most watches/clocks), or it may have a sticky mechanism caused by dust/or be in need of jeweller's oil on its cogs.
Post Fri Dec 15, 2006 10:28 pm
Prise the surround off, hold back the obvious clips, and it comes straight out of the dash.
**BANNED**
Post Sat Dec 16, 2006 1:35 pm
Excuse me butting in,does this type of clock have the slider thingy to make it light up at night?
Post Sat Dec 16, 2006 2:16 pm
daimlerman wrote:Excuse me butting in,does this type of clock have the slider thingy to make it light up at night?
Only thing I can think you mean is the light bar in the OBC. If so, answer is no. It's illuminated by a small bulb like most of the others.
**BANNED**
Post Sun Dec 17, 2006 11:31 am
Thats what I meant!!Thanks Brian.
