Removing engine
oldroydsr4
Hi currently removing an m20b25 for a rebuild and turbo conversion
everything is done, ie labelled loom, engine mounts, exhaust etc
bar undoing the bell housing,
What tools do i require for this.
also anything to bear in mind when lifting the motor.(first time with the bmw)
Chris-W
Nelly
- Gumbo
Andyboy
- Alpina Colada
Yup, gearbox comes out with the engine - ignore the Haynes manual. It's a bit tight between the PAS pump pulley and the front panel but it all comes out as one.
Nelly
- Gumbo
^^ forgot to mention (cheers Andy) disconnect the pas pump and leave it hanging in the bottom of the bay - no need to take anything apart on the steering side of things.
Before pulling the engine + box out together - disconnect the slave cylinder on the n/s of the bell housing (2x 13mm nuts)
Also, loom wise - just unplug the ECU and push the loom into the engine bay through the fire wall, disconnect the power leads and hey presto - the loom can come out connected to the engine still.
Neil.
Neil.
wildeian
If you jack the back of the car up as far as you can, the engine and 'box will come out nicely!!
(and you won't need to take the front of the car apart!!)
jmc330i
You using an engine crane? If so, get one of these....
Cost about 30 pounds and makes the job so easy. I removed/replaced the M20 and gearbox in one go using mine, no need to jack the back of the car up etc, just pops out the top
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
You've done that as well then!Nelly wrote: Before pulling the engine + box out together - disconnect the slave cylinder on the n/s of the bell housing (2x 13mm nuts)
Very useful tool. I bought one recently after swearing for years that I'd never take an engine out again without one. Finally bought it, and have used it twice so far.jmc330i wrote:You using an engine crane? If so, get one of these....
Could do with a couple of proper bearings though!
jmc330i
Yeah, thats my only complaint with it. There are more expensive ones with bearings etc, but they were nearer 100 pounds and held less weight IIRC.Brianmoooore wrote: Could do with a couple of proper bearings though!
I just greased the thread on mine and it worked fine.
James
'91 325i Sport
'91 325i Sport
SPADGE
Where from please?jmc330i wrote:You using an engine crane? If so, get one of these....
I'm forever pulling engines in and out and keep saying i must get one of these!
oldroydsr4 - Don't even bother trying to seperate engine and box in situ its far too much hassle and much easier to remove them both together as has been said already!
jmc330i
First google listing....SPADGE wrote:Where from please?jmc330i wrote:You using an engine crane? If so, get one of these....
http://www.justoffbase.co.uk/Load-Level ... tegory=134
I got mine from a local tool shop for 32 quid, about the same price as the above link once you add on postage.
Have a search through a couple of the online tool places, you might get one cheaper but watch out for the load rating. The draper one is 500kg, but Ive seen some with less that cost a few quid less - Id rather spend a bit more and get one thats definitely up to the job.
James
'91 325i Sport
'91 325i Sport
wildeian
SPADGE
Thanks guys
oldroydsr4
Thanks lads, if only i had known about the loom before would have saved ages.
- **BANNED**
Nelly and Brian,That makes three of us!!!I was able to bend the pipe back,though.
Speedo sender wires don't last long either when you suspend the diff by them!daimlerman wrote:Nelly and Brian,That makes three of us!!!I was able to bend the pipe back,though.
Nelly
- Gumbo
^^^ ROFL - talk about learn from your mistakes lol, yes i'm guilty of bending the 5hit out of the slave cylinder pipe and trying to extend the speed sensor wires with the diff along with snapping the occasional fan blade on the front panel - snapping the reverse sensor wires and trying to manipulate the oil cooler pipes into positions they where never designed for.
Years on - i know better now lol
Neil.
Neil.
- **BANNED**
Thanks for the tip ref the speedo sensor,when I come to swap my diff I will look out for it.When I was 18 or so I knew everything,seems like I have forgot alot as I grew up!!
wildeian
The definition of an an expert:seems like I have forgot alot as I grew up!!
Somebody who knows more and more about less, until they eventually know everything about nothing!!
- **BANNED**
Cheeky young bounder
