Coolant light on check control Panel
win
Mon Dec 11, 2006 11:23 am
Can anybody help? My coolant light keeps staying on and the car is not overheating any advice welcomed.
Win
SPADGE
Mon Dec 11, 2006 11:37 am
Isn't the coolant light on the check control panel for the coolant level rather than temp?
smithy318i
Mon Dec 11, 2006 11:46 am
check to see if your expansion tank isnt over filled.
Ziggy
Mon Dec 11, 2006 11:47 am
SPADGE wrote:Isn't the coolant light on the check control panel for the coolant level rather than temp?
Yep. If the level's ok, then you probably need a new sensor... could obviously be the wiring to it though, so I'd try shorting the pins on the level sensor first.
win
Mon Dec 11, 2006 11:52 am
Yes it is, but the level seems fine by the way cheers for the suuround got it on Friday
win
Mon Dec 11, 2006 11:55 am
yes the level is fine i think you may be right with the sensor i'll give that a try, Cheers
SPADGE
Mon Dec 11, 2006 6:03 pm
No worries mate cheers
Chris-W
Mon Dec 11, 2006 6:11 pm
Check the sensor hasn't been rotated first.
ian332isport
Tue Dec 12, 2006 9:05 am
Chris-W wrote:Check the sensor hasn't been rotated first.
Isn't that only for the windscreen washer tank sensor ?
Chris-W
Tue Dec 12, 2006 9:12 am
Absolutely right. Sorry. What day is it, nurse?
Tue Dec 12, 2006 9:23 am
If you buy a new sensor from GSF or Eurocarparts, check they give you the correct one.
GSF have twice sold me one for the tank on the end of the radiator type header tank, which will indicate low coolant when the tank is full and indicate OK when coolant is low.
There is a slight difference in length of the two types, so compare with your old one.
win
Tue Dec 12, 2006 12:01 pm
Brianmoooore wrote:If you buy a new sensor from GSF or Eurocarparts, check they give you the correct one.
Cheers i'll check when i go eurocarparts
6inline
Tue Dec 12, 2006 12:20 pm
Mine was 11ish from the dealer and there are two types.
