M10 Throttle body sizes?
PigPen
Do all M10 engines have the same throttle body?
I've had an idea to use 4 of them to make a cheap ITB setup. I've got one from an 87 316i which has a 42-43mm throttle plate. Anyone know if the throttles in the 318i and E28 518 all the same size?
maxfield
Didn't M10 engines have a carb
PigPen
They did an injected 316 M10 for about 18 months (87-88 ) before switching to the M40, and I'm told the M10 318 was injection after late 1984. My friend's E28 518 also had an injected M10.
Turbo-Brown
- Boost Junkie
Ryan? From 205GTidrivers?
Gwynleym10
There was a injected (L jetronic) m10 from about 1984 -1987 it was the 318i
PigPen
Yep.Turbo-Brown wrote:Ryan? From 205GTidrivers?
I've looked up the part numbers on RealOEM.com and it seems the same part is common to the 316i, 318i, and E28 518i.
Turbo-Brown
- Boost Junkie
So what engine are these destined for?
PigPen
My Mi16.
The M10 throttle body is nice and compact and has very little rubbish on the outside so I can mount them close enough together. Since they are seperate instead of being made as pairs with DCOE spacing like most aftermarket throttle bodies I won't need to buy an inlet manifold either, just cut down the standard inlet an inch or two after the injector holes and weld on a plate which the BMW bodies bolt onto. That way I can keep the original fuel rail too.
Turbo-Brown
- Boost Junkie
Good thinking, Batman
Be interested to see how you link them all up, you thinking Jenvey style or with a bar that runs the length of the engine and connects them up?
toby
This sounds really good - pictures of all this would be great when it's done.
Good luck.
Good luck.
PigPen
I'm thinking the simplest way would be to mount them with the throttle cable sides all facing upwards and link them all with a bar, something like this:
...depending on how much bonnet clearence there is as the engine is tilted back towards the rear making the inlet side stick upwards, plus the alternator is quite close underneath the left-hand end, but that could be moved down a bit.
toby
Maybe you've already seen this but...
http://e30m3performance.com/installs/2. ... umpets.htm
Just an idle thought about somehow angling them downwards with a spacer or something if space is a problem.
Turbo-Brown
- Boost Junkie
Funnily enough I'm working on a set of TBs for a V8 at the moment and had come up with exactly the same idea for the linkage. Nice and easy to adjust for throttle to throttle balance if you make the bar that links the throttles threadedPigPen wrote:I'm thinking the simplest way would be to mount them with the throttle cable sides all facing upwards and link them all with a bar, something like this:
PigPen
Great minds thinking alike?Turbo-Brown wrote:Nice and easy to adjust for throttle to throttle balance if you make the bar that links the throttles threaded
PigPen
I've never seen curved trumpets like that before. Bit out of my budget though.
DawieM3
Pigpen,
They are standard on the S14 M3 lump. 46mm standard and 48mm for evo III,.
Regards,
Dave
Regards,
Dave
