no sound stereo
spanner
Post Wed Dec 06, 2006 6:57 pm
Well just fitted a new system,speakers appeared to be blown as it had bad distortion.Good excuse for new speakers,after fitting no difference.It had alot of dodgy wiring so I took it back to basics,NO sound at all now,you can hear it in background if its flat out but thats it .To much volume and the speakers completely cut out.Never had any problems fitting units before so Im of the opinion there must be an amp fitted as standard somewhere.Its on a m3 1991 any ideas?
:cry:
Chris-W
Post Wed Dec 06, 2006 7:22 pm
If you've fitted a new head unit and speakers & speaker wiring , I cant see how the presence of an unknown amp could affect things?
toby
Post Wed Dec 06, 2006 7:28 pm
Are the speakers wired up wrong way round perhaps fella?
spanner
Post Wed Dec 06, 2006 7:39 pm
No wired right but Im using original speaker wiring.All wiring is the bmw loom connected to sony block.
noney82
Post Wed Dec 06, 2006 7:49 pm
i had this same problem, it turned out that the orig bmw wiring is not much cop, i pulled it out it it seems that the loop lives over to the speakers iv still got the orig harness, the best way to over come the problem is re-wire the speakers yourself, easy enough to do. i took passanger front seat out that where the side the wires run to the back.
toby
Post Wed Dec 06, 2006 7:54 pm
Ok is there isn't some silly switch or fader type misadjustment (you may have set by accident) on the headunit somewhere that is throwing things out?
If the wiring is the absolute original factory stuff there should be no chance of error.
I would make it simple and connect up the system using the old speakers just sitting on the floor and just normal wires to elimiante the chance of wiring fault in the old wires.
zaust
Zone day release
Post Wed Dec 06, 2006 7:59 pm
Sounds like at least one of the + spk wires is earthing out, as above change your speaker wire to fresh ones and then if you still got the problem look at the stereo.
M30 Tech 1 Touring on gas.
kam325itouring
Post Thu Dec 07, 2006 10:55 am
have you got the original fader still in the car???? if so Just rewire the speakers its easier!!
spanner
Post Thu Dec 07, 2006 5:05 pm
Thanks everybody
bought new cables today just going to rewire the whole thing.seems to have been the route most recommend.Keep me out of trouble if nothing else 8O
noney82
Post Fri Dec 08, 2006 2:18 pm
you should be ok with that mate like i said i had the same problem let us know the outcome
spanner
Post Tue Dec 12, 2006 7:05 pm
Sorted! rewired the thing from start to finish worked perfect from the word go.The standard wiring has to be checked out My yellow which was live feed turned out to be putting out 2 volts when I rewired the speakers,it was 12 before.Dont know why,dont care took new feed and it is fine. If I was doing it again I would just do the full rewire easy done and I would have had it finished in half the time winkeye
toby
Post Tue Dec 12, 2006 10:03 pm
Good for you and your Sony :cool:
noney82
Post Wed Dec 13, 2006 11:23 am
good to hear spanner, i never trust old wiring
