stereo cuttin off
jordano
my stereo keeps cuttin off wen i turn it up, it onli does it now and again and i hav checked all the wires, ne 1 ne ideas
jamesroools
what stereo you got
Dom
check the earth...
are you running amplifiers?
Blue_MK2
ok i take its a Sony headunit? yes/no??
You have to change the rear plug at the back of the unit. Do this ......
Buy one from Halfrauds (keep the reciept) now swap your shitty one over and return the fukker
Make sure your old one looks new though
Worked for me. mine used to cut out when the bass was turned up
while your at it check the (+) and (-) on all speakers. If they are connected in the wrong order the sterio can flash and the sound will be poor
amit325i
This is the symptom of clipping, where the speakers have a lower sensitivity being driven by low power amp. The headunit pumps more power to wires than it takes in, therefore it either switches of speakers or switiches off temporarily.
You could have a bad earth, but i doubt it, best to check voltages in the wiring with a suitable meter!
jordano
it is an alpine cda 7893 vi think, not runnin an amp as yet, but it is power infinity 125 watt rears and alipne 200watt front, it blew the fuse runnin from the stereo to the battery so i replaced it wit a 35amp one?
