for anyone thinking of turbo ing....
fuzzy
He who sleeps with "Gingers"
Post Wed Nov 29, 2006 8:05 pm
DO IT! ive just taken mine for a blast after 3 weeks of the road waiting for a new alternator and id forgotten just how fast it is.the power when you put the foot down from 30 in 2nd when the boost comes in is amazing :eek: stuff the christmas presents,im going to buy a set of bigger injectors so i can whack the boost up to 24psi and around 330 bhp just in time for some holiday fun :drive: :D
SPADGE
Post Wed Nov 29, 2006 8:18 pm
fuzzy wrote:DO IT! ive just taken mine for a blast after 3 weeks of the road waiting for a new alternator and id forgotten just how fast it is.the power when you put the foot down from 30 in 2nd when the boost comes in is amazing :eek: stuff the christmas presents,im going to buy a set of bigger injectors so i can whack the boost up to 24psi and around 330 bhp just in time for some holiday fun :drive: :D
What intercooler are you running mate?
As well as the dark green 803's you will need a 3 bar map sensor and a chip to suit!
march109
Post Wed Nov 29, 2006 8:22 pm
Whats it cost for a basic turbo setup? God I'm tempted.
SPADGE
Post Wed Nov 29, 2006 8:24 pm
march109 wrote:Whats it cost for a basic turbo setup? God I'm tempted.
His isn't a basic turbo set-up mate! Well actually it is for a Cosworth lol :D
march109
Post Wed Nov 29, 2006 8:26 pm
ok suppose. Don't fancy the cosworth route to boost lovlyness tho.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Nov 29, 2006 8:30 pm
I have been thinking about it for a future mod
fuzzy
Post Wed Nov 29, 2006 8:32 pm
SPADGE wrote: As well as the dark green 803's you will need a 3 bar map sensor and a chip to suit!
its all being taken care of mate,just under £600 for it all fitted then a bigger custom intercooler to be fitted in the space between the rad and the grill :cool:
fuzzy
Post Wed Nov 29, 2006 8:35 pm
im just at the beginning of the tried and tested cosworth tuning path.its going to be a long and bumpy ride :D
SPADGE
Post Wed Nov 29, 2006 8:43 pm
Tell me about it mate but after 8 years of modifying all things Cosworth its safe to say i know a thing or two :D
I hope your 600 quid isn't just for the injectors , 3 bar and chip mate as i can get you those for half that and fitting is a doddle :wink:
fuzzy
Post Wed Nov 29, 2006 8:46 pm
SPADGE wrote: Tell me about it mate but after 8 years of modifying all things Cosworth its safe to say i know a thing or two :D
tell me more.....does it need set up after these stage 3 bits are fitted or is it basically 'plug and play'?
E30cosworth
Post Wed Nov 29, 2006 8:48 pm
If you wait a week or two STU@MSD normally does a Xmas sale 25% off all prices i got 4x803's, 3 Bar Map, L8 Closed loop chip, last yr for my Saph fitted it all myself took about 1/2hr then all you need to do is get it checked and setup :D
SPADGE
Post Wed Nov 29, 2006 8:53 pm
Pretty much mate although someone with Cossie experience should check your fuelling etc...!
Old knobby bollox above has a point Stu normally does his chips a bit cheaper around now :D
fuzzy
Post Wed Nov 29, 2006 9:02 pm
what do you think is a more realistic price for the 803's,3 bar and chip,supply only? ive only got a level 6 ecu?ill then get it checked over by someone more experienced than me. the more i can save here the better obviously as my intercooler is going to cost me a few hundred quid to have made and then maybe i might have enough left to get my kids some christmas presents :D
SPADGE
Post Wed Nov 29, 2006 9:08 pm
fuzzy wrote:what do you think is a more realistic price for the 803's,3 bar and chip,supply only? ive only got a level 6 ecu?ill then get it checked over by someone more experienced than me. the more i can save here the better obviously as my intercooler is going to cost me a few hundred quid to have made and then maybe i might have enough left to get my kids some christmas presents :D
I can get 803's for about 150
3 bar 60
Chip around 75/100
I also know a good firm that will make you an i/c for around 250/300
E30cosworth
Post Wed Nov 29, 2006 9:44 pm
Alright mate this might be an option for you if you wanna save a few penny perfect intercooler for ya
If you can afford it go for a closed loop chip and fit a lambda sensor it will return you 30+mpg on a motorway run :D
it's all yours for £100+ postage
fuzzy
Post Wed Nov 29, 2006 9:51 pm
E30cosworth wrote: Alright mate this might be an option for you if you wanna save a few penny perfect intercooler for ya
interesting....what the dimensions of that intercooler?have you had it fitted to your e30 cosworth and if so where and how? winkeye
E30cosworth
Post Wed Nov 29, 2006 9:58 pm
Dimensions are it has 3" outlets
The intercooler measures Width=60cm, Height=46cm, Depth=4.5cm
haven't had it fitted to my E30 but mine currently runs a Pace RS500 intercooler, Pace Alloy Rad & Pace Turbo Pre-rad all Ford cosworth fitment i do believe he cut the chassis a tad to get them in
just have alook on here http://www.e30cosworth.co.uk
maxfield
Post Wed Nov 29, 2006 9:59 pm
fuzzy wrote: i might have enough left to get my kids some christmas presents :D
Your kids chose your retirement homwe :D :D :D
appletree
Post Wed Nov 29, 2006 10:18 pm
Is'nt that the volvo 740/940 turbo intercooler? when i spoke to ant about doing a turbo set-up thats what he suggested. and what he used on his :D apparently it the best volume to size cooler you can find with out goin mega bucks.
it fits infront of the normal e30 raditor and then the outlets point backwards either side of the raditor.
PPC 335 turbo is using the same one. :D
Toby_Unna
Boost Junkie
Post Fri Dec 15, 2006 1:12 am
appletree wrote:Is'nt that the volvo 740/940 turbo intercooler?
yes that's the intercooler I have. a good fit for an E30, and big enough for plenty of boost :D
