Powerflex subframe bushes
EOS
Mon Nov 27, 2006 7:42 am
Has anyone on here fitted some powerflex subframe bushes? And what improvments if any did they get from this. Was thinking about changing them now as none of my rear brake lines are connected and i got to take the diff off and other bits back there anyway. Only thing is I don't have a press, will i need one to fit the powerflex bushes? Im sure i can get the old ones out with some burning cutting etc.etc.
ed325i
Mon Nov 27, 2006 2:38 pm
You wont need a press to fit them they just push in.
stuartgallafant
Mon Nov 27, 2006 2:52 pm
Tonyppe has them on his. he really rates them
ROC
Mon Nov 27, 2006 3:57 pm
I put them on my car when the standard ones were shot. As you know they cost a good bit more than standard but won't need doing again (which has gotta be a good thing :) )
Once you get the old ones out the Powerflex are easy to fit, I can't say I noticed a vast increase in road noise.
DRIFTBOY
Mon Nov 27, 2006 4:13 pm
I've not noticed any negative effects either.
And I'm glad I won't have to get standard ones out again! :D
Silverfang
Mon Nov 27, 2006 5:22 pm
Got them here too, can't rate them high enough, the back end does feel more planted after the swap :D
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Karan
Mon Nov 27, 2006 5:48 pm
they are great!
stuartgallafant
Mon Nov 27, 2006 7:58 pm
how much are they compared to the OE bushes?
wells696
Mon Nov 27, 2006 8:31 pm
are they hard to get out iv been looking for these bushes and cant find then anywhere can any help
got my white coupe for sale
DRIFTBOY
Mon Nov 27, 2006 8:34 pm
Take a look at this link from the Zone shop!
http://www.xsperformance.co.uk/e30zone/ ... cts_id=111
stuartgallafant
Mon Nov 27, 2006 8:35 pm
the worst part of the job is getting the 2 x 6mm hex nuts out of the brackets on the sills. they're always rusted to f*ck and just totally sh!t
getting the bush rod out of the chassis can be a pig, but theres a knack to it!!
trigger
Mon Nov 27, 2006 11:52 pm
stuartgallafant wrote:the worst part of the job is getting the 2 x 6mm hex nuts out of the brackets on the sills. they're always rusted to f*ck and just totally sh!t
would you care to divulge 'the knack' as ive got to do mine soon and not looking forward to it, ive heard too many stories i think!
any info that would make this task easier would be gratefully taken on board! :D
EOS
Tue Nov 28, 2006 7:03 am
Yeah that would be helpful if you have any little tricks that make this easier? Haynes manual probably just says, undo bolts, take out bushes, replace bushes bolt back up :roll:
Defo looking to get under the car this weekend and have a go at fitting some.
stuartgallafant
Fri Dec 01, 2006 6:05 pm
once you've got the plates off the car, and the bolt from the middle, just put a large extension bar through the bush, and wiggle the hell out of it!!
