Powerflex subframe bushes
EOS
Has anyone on here fitted some powerflex subframe bushes? And what improvments if any did they get from this. Was thinking about changing them now as none of my rear brake lines are connected and i got to take the diff off and other bits back there anyway. Only thing is I don't have a press, will i need one to fit the powerflex bushes? Im sure i can get the old ones out with some burning cutting etc.etc.
ed325i
You wont need a press to fit them they just push in.
stuartgallafant
ROC
I put them on my car when the standard ones were shot. As you know they cost a good bit more than standard but won't need doing again (which has gotta be a good thing
Once you get the old ones out the Powerflex are easy to fit, I can't say I noticed a vast increase in road noise.
DRIFTBOY
I've not noticed any negative effects either.
And I'm glad I won't have to get standard ones out again!
Silverfang
Got them here too, can't rate them high enough, the back end does feel more planted after the swap
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
Karan
they are great!
stuartgallafant
wells696
are they hard to get out iv been looking for these bushes and cant find then anywhere can any help
got my white coupe for sale
DRIFTBOY
stuartgallafant
trigger
would you care to divulge 'the knack' as ive got to do mine soon and not looking forward to it, ive heard too many stories i think!stuartgallafant wrote:the worst part of the job is getting the 2 x 6mm hex nuts out of the brackets on the sills. they're always rusted to f*ck and just totally sh!t
getting the bush rod out of the chassis can be a pig, but theres a knack to it!!
any info that would make this task easier would be gratefully taken on board!
EOS
Yeah that would be helpful if you have any little tricks that make this easier? Haynes manual probably just says, undo bolts, take out bushes, replace bushes bolt back upwould you care to divulge 'the knack' as ive got to do mine soon and not looking forward to it, ive heard too many stories i think!
Defo looking to get under the car this weekend and have a go at fitting some.
stuartgallafant
