http://cgi.ebay.co.uk/BMW-RANGE-ROVER-2 ... dZViewItem
Probably shouldn't link from here so apologies if it's not allowed!
Cheers!
Anyone know if the crank from this will go into an M20?
Turbo-Brown
- Boost Junkie
Toby_Unna
- Boost Junkie
i think it's chain rather than belt, unaware of any other issues
Turbo-Brown
- Boost Junkie
Hmmmm, they forged?
And finally does anyone know the stroke?
Cheers Toby
Cheers Toby
Laimis
IIRC they are forged and the stroke is 82.8mm.
It will need some machining to fit M20, but it's doable, because i seen few e30 here arround with this crank.
Anyway, i heard that 2.5TDS crankshaft sometimes break in two pieces, also and 1.8TDS .. Dunno why
I think M52B28 crank is better choice, 84mm stroke, forged, and i never seen any broken.
Turbo-Brown
- Boost Junkie
Interesting to know about the M52 crank, and the TDS cranks breaking
Would prefer not to go too far away from the standard M20 stroke though as it's likely to mean fitting shorter rods.
Laimis
Or custom pistons.Turbo-Brown wrote:as it's likely to mean fitting shorter rods.
