multilpe m20 throttle bodies
tee
Post Thu Nov 23, 2006 9:40 pm
Has anybody on here ever fitted multiple throttle bodies to a M20 engine?
A company in the States called BMP Design used to sell a kit for about £1500 but dont sell them anymore :(
Just wondered whether anybody had tried and got any useful gains? Also want them cos they look good, but £1500 for looks is alot.
Tee
maxfield
Post Thu Nov 23, 2006 9:44 pm
i know player6 has ITBs
theres someone from south africa i think aldo doing it???
Andy335Touring
Post Thu Nov 23, 2006 9:58 pm
Theres more to them than looks but to get the best out of them you have to have a well modded engine to justify using them really.
TurboBrown(Alex) has some he made him self for his turbo'd 2.5 M20
Andy335Touring
Post Thu Nov 23, 2006 9:59 pm
Just to add if you are good at modding have you thought about using bike TB's ?
Turbo-Brown
Boost Junkie
Post Thu Nov 23, 2006 10:07 pm
Mine took an age to make, although I've since come up with a simpler way of doing it which is soon (within the next couple of months) to find it's way onto an absolutely insane spec V8 so if you're interested then gimme a shout :)
The real benefit is the taming of crazy overlap cams although generally speaking ITBs offer lower restriction to flow than a plenum intake.
They also offer pin sharp throttle response which is why I made a set for mine :)
tee
Post Thu Nov 23, 2006 11:17 pm
I am definately interested in making these. They will be going onto a modded 2.7. Do yours feed from a plenum chamber or have you got trumpets?
Turbo-Brown
Boost Junkie
Post Fri Nov 24, 2006 8:07 am
Mine feed from an airbox/plenum as they're fed by a pair of turbos, although if I'd been making them for N/A use I'd still have used an airbox so that the trumpets didn't suck up hot air.
They do have trumpety pickups in the air box though
Don't forget to take lots of piccies!
Be very interested to see how you get round the same problems I had like clearing the servo and the like.
ajm-e30
Post Fri Nov 24, 2006 8:13 am
i no someone who has triple webber 45's on his 325i,
Turbo-Brown
Boost Junkie
Post Fri Nov 24, 2006 8:17 am
Aah that reminds me!
What size TBs are you gonna make tee?
tee
Post Fri Nov 24, 2006 8:56 am
Turbo-Brown wrote:Aah that reminds me!
Havent got a clue yet. Is it the bigger the better or is there a limit?
Just remembered I have seen some BMW K1200 motor bike throttles lieing around at work!!!
Post Fri Nov 24, 2006 9:05 am
i am no authority whatsoever on things like this, but I would personally not use anything above 40mm diameter
Turbo-Brown
Boost Junkie
Post Fri Nov 24, 2006 1:36 pm
Yeah, it's definately use the right size or regret it.
The ports are about 36mm on the 2.5 M20 so using 38mm should work out nicely.
I did 40mm/cyl for mine and it does lack a little in low end torque, although that could be improved if I switched to smaller diameter runners (currently 48mm).
Jenvey's site says that 40mm/cyl is enough for 50bhp/cyl so unless you reasistically expect to get more than 300bhp N/A from your engine I'd treat that as the upper limit.
tee
Post Sat Nov 25, 2006 3:14 pm
Turbo-Brown wrote:Yeah, it's definately use the right size or regret it.
What are "runners" mate? the tubes from the plenum chamber to the throttle bodies?
Turbo-Brown
Boost Junkie
Post Sun Nov 26, 2006 11:28 am
Yep, exactly that :)
trigger
Post Sun Nov 26, 2006 2:32 pm
dont forget that with multiple carb set ups there is a little more that can be taken into consideration as the length of the intake tract can greatly effect the perfomance as to wether you want low down, mid range or high end performance. the tuned length should also be matched with considerations to the exhaust side of things to have substancial gains . when i used to race hot rods this entailed many hours and expense and time on the track and rolling roads experimenting with intake manifolds of varying lengths and the length of the trumpets was greatly significant performance wise!
Turbo-Brown
Boost Junkie
Post Sun Nov 26, 2006 3:21 pm
Very true indeed, although if you can make up a flange that accepts Weber type trumpets or something that's common, you can make it relatively easy to experiment with your tuned lengths.
Problem with the 325 is that there's not very much room to play with unless you opt to stick the air box ontop of the rocker cover.
Would imagine that the standard runner length would be a good starting point for length :)
Andyboy
Alpina Colada
Post Sun Nov 26, 2006 3:42 pm
ajm-e30 wrote:i no someone who has triple webber 45's on his 325i,
What you can do is buy a triple carb inlet manifold from Mangoletsi and buy three old Weber 40DCOE's. The Webers can be gutted of all the jets, sleeved and fitted with an injector per choke. It's been done on all kinds of engines so why not a BMW? You'd need Megasquirt to make it all work but you'd need a pretty hairy cam to get it all running okay.
250 bhp?
Turbo-Brown
Boost Junkie
Post Sun Nov 26, 2006 4:02 pm
Don't the magnolesti manifolds point no. 6 cylinder's inlet straight at the servo though?
Think 250bhp from one of these that's gonna be used on the road is a bit optimistic, especially when you consider that Scott Player's 2.8 on throttle bodies makes 260bhp so on a pro-rata basis a 2.5 could perhaps make 230bhp?
Why would you need a hairy cam to make it run too? :?
tee
Post Sun Nov 26, 2006 9:12 pm
Finally found the BMP Design catalogue, heres the multithrottle body kit they used to sell
Andy335Touring
Post Sun Nov 26, 2006 9:16 pm
link doesn't work, i think they sold the Dhiblas(Sp?) TB's the same as Scotts ?
tee
Post Sun Nov 26, 2006 9:20 pm
Andy335Touring wrote:link doesn't work, i think they sold the Dhiblas(Sp?) TB's the same as Scotts ?
Yeh there the ones!
Cant seem to insert image? ah just realised I have uploaded the pic to a private forum. where can I publicaly post pics up??
Andy335Touring
Post Sun Nov 26, 2006 9:28 pm
Yeah, try this place :thumb:
http://www.imageshack.us/
tee
Post Sun Nov 26, 2006 9:35 pm
See if this works
tee
yay :D
player6
Post Sun Nov 26, 2006 9:41 pm
the Dhiblas tbs and the BMP ones are the same
scot 328i with 260bhp
Andyboy
Alpina Colada
Post Sun Nov 26, 2006 10:03 pm
I guess you'd use a standard BMW cam then! :mad:
Turbo-Brown
Boost Junkie
Post Sun Nov 26, 2006 10:27 pm
All depends on what you're doing with it really, but there's absolutely reason why it wouldn't run perfectly with the stock cam and a set of ITBs, and my car is living proof.
Agreed that the point of fitting ITBs is to enable efficient and effective use of wild cams, but they're not a pre-requisite.
Andyboy
Alpina Colada
Post Sun Nov 26, 2006 10:41 pm
True, but stick a pair of 40DCOE's on a standard 2 litre Pinto - sod all torque at the bottom end unless you fitted tiny chokes and not much at the top end either because the valves don't open deep or long enough to get the benefit. You could fit a cam from a Rolls Royce 20/25 and it would idle and run, but........
I'm going back years and years now to a Mark 2 Escort Mexico I had and it was just awful on 40DCOE's and savage on fuel. It had to be choked and jetted down to the point where really, it only gave 15 bhp more than a standard car with the 32/36 Weber and it was horrible to drive. With a Burton cam (can't remember the profile) it went like a rocket and I fitted an Aldon (?) rev limiter because it just revved to 6000 and beyond. I'm not suggesting some 302 degree race cam, but a nice spiky 285 degree stick would make it really go.
Anyone ever seen a Hartge H27SP??
tee
Post Sun Nov 26, 2006 11:23 pm
Whos car is this? tried to search "Dhiblas" and got nothing. Anyone know the name of this fit and if it is still available anywhere?
e21Jason
Post Mon Nov 27, 2006 12:44 am
Hi
I got set of e36 m3 throttle bodies modiifed to fit my car but i think they wil be too big I must measue the area some time, The Mangoletsi manifolds are for down drafts made for LHD to clear the steering column & brake booster.
The only place i know to get a side draft manifold is from fritz bits & use sem jenvy throttle bodies.
Jason
PS I will sell my throttle body setup 1k
Demlotcrew
Post Mon Nov 27, 2006 9:37 am
Are they not Dbilas?
Andrew
e21Jason
Post Mon Nov 27, 2006 12:45 pm
Hi
Regal autosport sell the Dbilas set up in the UK, the BMP is a rebranded version of the Dbilas
Jason
Post Mon Nov 27, 2006 1:08 pm
So has any hero been sick /rich enough to do this ?. What did it cost (honestly) and what gains were made ?
harry_p
Post Mon Nov 27, 2006 1:39 pm
Andyboy wrote:True, but stick a pair of 40DCOE's on a standard 2 litre Pinto - sod all torque at the bottom end unless you fitted tiny chokes and not much at the top end either because the valves don't open deep or long enough to get the benefit. You could fit a cam from a Rolls Royce 20/25 and it would idle and run, but........
remember, that while they look similar, they work completely differently.
a carb needs airflow though it to draw out and atomise the fuel, which is why one too big will run like poo low down.
throttlebodies don't suffer from this at all as youre using a standard high pressure fuel injector which will inject the amount of fuel you want, when you want, and do a good job of atomising it.
my metro has a 1.8 k-series and runs jenvey direct to head throttlebodies, its on standard cams and starts and idles as smoothly as the standard car and has sharper throttle response and instant grunt all the way up the rev range.
however, their main advantage is that they do let you run a wild cam, without getting the pulse effects low down which make most plenum based setups really lumpy.
e21Jason
Post Mon Nov 27, 2006 1:45 pm
Hi
Throttle bodies do not have chokes, so they are closer to the choke size than the carb size when swapping them over.
I just think i need ot buils a 3.2 to make the most of my 50mm throttle bodies
Jason
