Water getting in??
samr
Post Mon Nov 20, 2006 5:16 pm
Hey guys and girls.
Discovered this morning the passenger seat was pretty damp, with some "Rain drop" splodges on it. Cars a 1991 2dr, with manual sunroof. Cant see how water cud be getting in. Also the sunroof "jumps up" when you close one of the doors! Any ideas?
Many Thanks for help in advance
Nelly
Gumbo
Gumbo
Post Mon Nov 20, 2006 5:33 pm
The jump from the sunroof panel is a common trait with E30's.
Believe it or not the sunroof seal is designed to let in water - the water then travels along the sunroof rails and eventually into drain-off pipe work which is attached at all 4 corners of the sunroof mechs and exits under the car.
If one of these pipes is blocked it causes a build up of water which eventually leaks into the cabin - as well as rusting the hell out of the under side of the roof panel.
Your gonna get a bit wet doing it but, get a jet wash as close to the pipes and fire away - not for to long though or try the old wire pushing job on them.
Neil.
"I F**KING LOVE YOU GUMBO"
jcjdavis1
Post Mon Nov 20, 2006 8:33 pm
Hi Have you cleaned out below scuttle panel for leaves and debris.Then take off elephants trunk and clean that out,located on drivers bulkhead in engine bay.Thats how I stopped mine.
samr
Post Tue Nov 21, 2006 5:52 pm
Big thanks to Nelly and jcjdavis1
That makes sense.
I'll go try now!
Cheers guys.
