btb manifold (m20)
jimerilo
Ive just purchased a mild steel btb manifold but ive noticed that it doesnt have a thread/hole for the lamba senser? is this right? surely my sport wont run properly if this isnt fitted?
any info will be greatly appreciated.
Templ8e30
I assume you'll be ditching the cat anyway if you fit this manifold (if it actually had one) ?
If so ditch the lambda sensor, the ECU will operate in open-loop mode (like all non-cat models) and you may find it runs better.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
jimerilo
Thankyou for the info Templ8e30
My car doesnt have a cat fitted but has a two piece exhaust system so abit of modding needed.
When you say ditch the sensor do you mean dis connect from loom at connector or just zip tie up out the way still plugged in?
cheers.
cheers.
toughguych
jimerilo mate,
I am thinking of getting a 6 branch.
I also have a two part exhaust which I fitted 18 month ago so dont want to swap out.
I would be interseted to know how you get on fitting the 6 branch manifold to your two piece.
Templ8e30
You'll need to unplug the sensor from the wiring loom.
If you find an E30 in the scrappies without a Lambda sensor there should be a dummy plug for the wiring connector, get hold of one to protect it from water and dirt.
The dummy plug has no connectors in it and you can run the car without it.
Cheers,
Iain T
Cheers,
Iain T
toughguych
Surely thats just the same as tying it out the way?
Wouldnt a bit of insulating tape at the sensor end of the wire do the job?
Asking cause I need to do mine!
jimerilo
Templ8e30 thanks again for your info, much appreciated.
toughguych, will post up some pics/info on how i fitted it once complete.
Templ8e30
Nope, it's an oxygen sensor that gives a small voltage output corresponding to the oxygen content of the gas its sensing. If you just remove it from the exhaust but leave it connected to the wiring it'll be sensing free air instead of exhaust gas giving a false reading and the engine will run badly.toughguych wrote:Surely thats just the same as tying it out the way?
Cheers,
Iain T
toughguych
Thanks for the info Iain.
he30
Not really related fella, did you get your mates number for the wheel refurb?
jimerilo
Now then mate totally forgot about that sorry,
gonna see him early next week so will let you know.
he30
I'm looking at modding my engine fella, nowing you've had some work done mate, where would you say the best place to start is ? Looking for a winter project. Don't want anything that can't be reversed as my cars pretty standard, just a few little tweeks!...thoughts?
Cheers he30
Cheers he30
jimerilo
He30 you have pm
jimerilo
Finally got round to fitting my manifold a few days ago and everything about the manifold is very good. My car feels soooo much more eager to rev, sounds well and feels alot quicker
For anyone out there thinking about purchasing a manifold, btb seem to be well worth the money.
james.
james.
