E30Zone chip petrol question
Pikey
Post Fri Nov 17, 2006 2:30 pm
Are the chips designed for normal 95RON petrol? Or do you have to use 97/98/99RON Super?
d6dph
Post Fri Nov 17, 2006 2:35 pm
I believe they are all 95 ron, best person to ask is Ant.
Jon_Bmw
Dangerous when thinking
Post Fri Nov 17, 2006 2:48 pm
Considering as it doesn't have knock sensors it makes no difference whether you put 95/97/99 in. It will work fine on 95 ron fuel.
320Touring
Post Fri Nov 17, 2006 2:49 pm
Jon_Bmw wrote:Considering as it doesn't have knock sensors it makes no difference whether you put 95/97/99 in. It will work fine on 95 ron fuel.
too true dude. anything above 91 octane and she's good
Pikey
Post Fri Nov 17, 2006 3:00 pm
Jon_Bmw wrote:it makes no difference whether you put 95/97/99 in. It will work fine on 95 ron fuel.
So that means I could get even more benefit from a chip specifically designed for use with higher octane fuel?
320Touring
Post Fri Nov 17, 2006 3:03 pm
No, it means, that unless your car is fitted with a MAF control system that van be mapped for a given octane rating, you'll recieve no benefit from spending more of your hard earned on "super" unleaded
Pikey
Post Fri Nov 17, 2006 3:54 pm
Ok, how does the ecu know how much fuel to put in then?
320Touring
Post Fri Nov 17, 2006 3:57 pm
Pikey wrote:Ok, how does the ecu know how much fuel to put in then?
Thats what the big Black box behind the air filter is for. Measures the airflow, and sends signal to ECU, that coupled with throttle position tells ecu fuel required.
As said before- speak to ANT about this- he can go into much more detail, if you have any specific questions related to fuelling, or engine management :D
Pikey
ps please forgive all the n00b questions :o:
