Heater issues
boomer
Post Fri Nov 17, 2006 6:48 am
My heater fan seems to have given up the ghost on position 1, runs intermittently (cycling) on position 2 and occasionally stops on position 3. Position 4 is fine.
Anyone have any pointers on what the problem is?
Post Fri Nov 17, 2006 9:15 am
Motor has partially seized. The plain bush bearings need a drop or two of oil every fifteen years or so.
Motor is behind the removable bulkhead panel at the rear of the engine compartment, and to do the job properly, the motor/fan assembly has to be removed, bearings oiled, powered up out of the car, oiled again etc., etc., until it runs free
boomer
Post Fri Nov 17, 2006 10:16 am
Yikes!
At least there's no black magic involved
Thanks Brian
