no heaters
dazleeds
old skool raver
old skool raver
Post Fri Nov 10, 2006 11:51 am
325i d reg early car
no heat at all thru the fans
fan is blowing and theres no overheating at all of engine
some one suggested tstat could be missing??
what else could this be??
as many suggestions as poss please
want this fixed asap as its now bloody freezing up here
and after next week this will be my daily hack
cheers
Daz
www.oldskoolfantasy.co.uk
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Fri Nov 10, 2006 11:54 am
Crossing my fingers for you that its not the heater matrix, you havent been playing with anything in the dash have you? My cousins one went last december and he went without a heater for a good few months as he couldnt afford to fix it!
or the heater duct could have come out? (no idea how it would fall off but you wanted as many suggestions as possible)
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
gcorky
Boost Junkie
Post Fri Nov 10, 2006 11:55 am
is engine at running temp?heater temp valve?(is one hose hot and one cold going to heater?)blocked heater matrix?
ill send ya some fishermans freinds and a flask for a tenner winkeye
525 sport
dazleeds
old skool raver
old skool raver
Post Fri Nov 10, 2006 11:56 am
all answers will be looked at dobbie
i have a feeling its gonna be a pain in asss job so the more things i can check the better
i havent messed with it got it like this :cry:
far too cold for no heat 8O
will check all ducts :wink:
all seems to work perfect, just no heat :roll:
dobbie82
Post Fri Nov 10, 2006 12:01 pm
Simplest one is the dial that you turn to chose the temparature, it may turn on the outside but you could pull it out and test if its turning on the inside?
Steviec
Post Fri Nov 10, 2006 1:14 pm
Might be worth trying to replace part 25:
http://www.realoem.com/bmw/showparts.do ... g=64&fg=20
Im sure someone on here could help you out.
<a><IMG></a>
Chris-W
Post Fri Nov 10, 2006 3:35 pm
Do you hear the 'clunk' when turning the dial from cold to hot?
Wookie
Post Fri Nov 10, 2006 3:44 pm
No airlocks in the heater matrix perhaps?
There are two types of drivers: Those who dislike BMW drivers, and those who drive BMWs.
tomtomiS
Post Fri Nov 10, 2006 3:49 pm
check the heater valve by where it enters the matrix. they normally fail open so water can circulate round the matrix. mine was a bit iffy on my 316 so i tapped it gently and it started sending water round the matrix again. its been a while since i did that but if i remember rightly the bit u need to look for is on the left hand side of the matrix on one of the pipes. hope this helps, 2 minute fix if it is. good luck
dobbie82
Post Fri Nov 10, 2006 3:55 pm
Steviec wrote:Might be worth trying to replace part 25:
ed325i might have one as I left it in the dash I sold him, failing that I will be taking one out of my 318i sunday or wednesday if you can cope with the cold till then! (unless I can get it out without taking the dash off completely then i may be able to get it tomorrow if someone shows me how I take it out!)
dazleeds
old skool raver
old skool raver
Post Fri Nov 10, 2006 4:02 pm
still using the sport for a few
so ill get back to you Dobbie if i need that part
will have a good look and mess about with things over the weekend
cheers for all the suggestions so far :D
J_Mac
Post Fri Nov 10, 2006 4:23 pm
not really had a chance to have a look at the bypass valve in my bm if at all it has one but i had exactly the same thing in an old mk2 golf, it was that, the bypass valve, it's basicly a valve that stops alot of pressure building up in the heater matrix and in return cracking and pissing out everywhere inside the car, i'll have a look see if i see anything i reconise in my engine bay and look it up in the haynes
Post Fri Nov 10, 2006 9:46 pm
Very first thing to check is that the heater hoses are on the right way around.
The way that looks the most "correct" is the wrong way. Hose from the back of the cylinder head goes to the lower stub.
blingsta
Boost Junkie
Post Fri Nov 10, 2006 10:09 pm
yeah, i made exactly the same mistake, i had heat for 20secs, then went cold
