HID Conversion Kit A few questions
e30bemer
Nutters
Nutters
Post Wed Nov 08, 2006 7:23 pm
Looking to get a HID kit, as my lighting is a bit poor!
Have seen a few fitted to cars on here, i know demlot does it, but i was looking at some kits on the dreaded ebay,
The ones from there, are they reliable, and easy to fit!
Has anyone got any experience on fitting them how easy is it! etc etc
many thanks
Adam
ifty
Post Thu Nov 09, 2006 2:40 pm
i got one from ebay its a uk seller very very easy to fit.i got the 8000k kit which is crystal blue light or you can get the 6000k more of a white light.as im blind and cant see very well at nite these kits are excellent.if you require any more info on the kit or fitting pm me more then happy to help.
ifty
Post Thu Nov 09, 2006 2:43 pm
adam did you stop me at tesco in leyton few weeks ago?i think i gave you my number
Martinaston
Post Thu Nov 09, 2006 2:46 pm
You loose the half beam when you fit HID's. No great loss though.
There is NO nucleus.
Chris
Post Thu Nov 09, 2006 9:36 pm
What do you mean by Half Beam?
Surely not diped?
Martinaston
Post Fri Nov 10, 2006 7:30 am
Without the key in if you pull the light switch out one click it turns your side lights on (5 watt bulb) but if you start the engine it also turns on the low beam lights (55 watt) at half power. Its only when you pull the switch to position 2 that the main beam comes on at 55 watts.
So if you fit a hid kit as they will only work at a set voltage (i.e. full power) you loose the half beam, so its either on or off.
I nearly bought a set at santa pod but when the guy started scratching his head when i mentioned it i decided to leave it until i was sure.
boomer
Post Fri Nov 10, 2006 8:36 am
You've just made my head hurt because I don't understand that.
:mad:
e30bemer
Nutters
Nutters
Post Fri Nov 10, 2006 8:45 am
ifty wrote:adam did you stop me at tesco in leyton few weeks ago?i think i gave you my number
Im not sure there fella!
I might have done??
Looking at ebay, to get a set, who did u get yours from??
Post Fri Nov 10, 2006 9:07 am
Martinaston wrote:You loose the half beam when you fit HID's. No great loss though.
This was only fitted to early post facelift cars.
Can easily be disabled by pulling apart two round rubber two pin plugs and sockets at the front of the LH inner wing.
The resistors for the set up are mounted just beside the LH headlamps on the wing, and many will have long since expired.
ifty
Post Fri Nov 10, 2006 12:48 pm
didnt really like the half beam as ive got bright led side lights and then u had this yellow half beam on to.changed my lights to the smillies much beta now.recommend it all.it turns heads day and nite go 4 the 8000k kit!!!
ifty
Post Fri Nov 10, 2006 12:51 pm
adam if you need any help let me know or if u want to see the kit on my car gona be down leyton next week.
buster
Post Fri Nov 10, 2006 4:05 pm
I think all e30's have this.My 1990 sport has one.
It just puts the dip beam bulb on dim when the key is taken out.
Demlotcrew
Post Fri Nov 10, 2006 5:17 pm
Im with Brain on this, only early cars.
Andrew
oze30
Post Fri Nov 10, 2006 5:18 pm
My J reg touring does this.
Dan318-is
Post Fri Nov 10, 2006 5:21 pm
ifty wrote:i got one from ebay its a uk seller very very easy to fit.i got the 8000k kit which is crystal blue light or you can get the 6000k more of a white light.as im blind and cant see very well at nite these kits are excellent.if you require any more info on the kit or fitting pm me more then happy to help.
link?
wiledw
Post Fri Nov 10, 2006 5:25 pm
My 1990 H reg 318is does this.
buster
Post Fri Nov 10, 2006 5:27 pm
Demlotcrew wrote:Im with Brain on this, only early cars.
Andrew
Oh well,i must be imagining it,infact it was you who told me what it was when i asked ages ago !!
jmc330i
Post Fri Nov 10, 2006 7:00 pm
oze30 wrote:
buster wrote:
Brianmoooore wrote:This was only fitted to early post facelift cars.
My 318i touring (which is an early touring 1989) does the half dip beam thing and so does my late 1991 325i Sport.
I dont think I would be bothered about not having it if I fitted HID's.
James
'91 325i Sport
'93 318i touring 16v
Post Fri Nov 10, 2006 9:22 pm
I've about ten facelift E30s here, and only the two with '88 production date have any of the dim dip circuitry. All of the later ones do not have the resistors, the relays, or any of the associated wiring (which is part of the main body loom).
ifty
Post Fri Nov 10, 2006 10:14 pm
SGP
Post Fri Nov 10, 2006 10:18 pm
my 89 320i dips when the key is removed, I thought this was designed to save your battery in case the headlights were left on.
If it ain't broke..
Fix it till it is :)
Estoril-5
Post Fri Nov 10, 2006 11:22 pm
Ifty you got any pics of your car as that kit is super cheap!
Is it reliable? :?
ifty
Post Sat Nov 11, 2006 1:34 pm
i'll take some pic today i have the same kit mine are on day and nite no problems.
e30bemer
Nutters
Nutters
Post Sat Nov 11, 2006 3:42 pm
if u can get some pictures up with them on, and maybe some pics of the install @ the back aswell
cheers
**BANNED**
Post Sat Nov 11, 2006 4:13 pm
I have dim dip on the 89 320i,but not on the 93 316i Touring.Seem to remember it was a legal requirment for a while in the 80s,the idea was that pedestrians could tell that a car showing dim dip was moving.In the days of dynamo electrics we used to run on sidelights in town to`save the battery`anyone else old enough to remember?
Post Sat Nov 11, 2006 6:31 pm
Do the bulbs fit straight in to the lamps with no modifications? May get a set of these as theyre plenty cheap
ifty
Post Sat Nov 11, 2006 7:45 pm
Here are some pictures, sorry for the bad quality that's mobile phones for you. I'll post some pictures of the box and connections tomorrow.The bulbs are the same as halagon lamps so no modification required.
d6dph
Post Sat Nov 11, 2006 8:11 pm
Have you had any comments from the police with reguards to their legality?
ifty
Post Sat Nov 11, 2006 8:17 pm
nope nothing from the police as they look like what you get on new cars,went through 2 mots i think its when you get the very blue ones 10000k(colour temp)upwards.
e30bemer
Nutters
Nutters
Post Sat Nov 11, 2006 8:48 pm
thinking that i will grab a set of these!
By the sounds of it they were easy to fit!
8000k sounds like the kit to get!
liam012
Post Sat Nov 11, 2006 8:50 pm
i dont get it - isnt 4300 maximum visibility?
anything higher just gets bluer?
Post Sat Nov 11, 2006 8:53 pm
liam012 wrote:i dont get it - isnt 4300 maximum visibility?
Thats what I thought
ifty
Post Sat Nov 11, 2006 9:04 pm
very easy to fit just 2 wires you need to connect positive negative.Hid 8000k arnt that blue like the halagon bulbs which the 7500k are very blue as ive had the piaa plasma spark blue bulbs.
Post Sat Nov 11, 2006 9:22 pm
daimlerman wrote:anyone else old enough to remember?
Sure am!
Dan318-is
Post Sat Nov 11, 2006 9:26 pm
So are these any good or not?
