OBC Problem!
Greeny
Post Wed Nov 08, 2006 3:52 pm
Hi all.
I have a problem with the on board computer on my '92 325i convertible, on everything but the time and date screen I keep getting 'PPPP' on the display. In the owners hand book it just say's to refer to BMW. I had the same problem on my E34 530i but I can't remember how I fixed it. Anyone out there got any idea or know how to reset it?
Greeny
orangecurry
Post Wed Nov 08, 2006 4:01 pm
I think if you disconnect, then reconnect the OBC with the ignition on, it can clear the PPPP fault code.
smithy318i
Post Wed Nov 08, 2006 4:04 pm
pull the power to the unit then plug it back in with the ignition on and it clears the problem .
orangecurry
Post Wed Nov 08, 2006 4:05 pm
3 minutes too slow winkeye
Greeny
Post Wed Nov 08, 2006 4:08 pm
Thank's. I'll go give it a try. Although I could do without seeing how few miles to the gallon i,m doing. :eek:
orangecurry
Post Wed Nov 08, 2006 4:09 pm
24.5 :(
but it's a short trip and I enjoy my driving :D
Greeny
Post Wed Nov 08, 2006 4:34 pm
Now that my fingers are bleeding and I have scrapped knuckles anyone know how you get the OBC out of the dash board.
tomtomiS
Post Wed Nov 08, 2006 4:48 pm
Greeny wrote:Now that my fingers are bleeding and I have scrapped knuckles anyone know how you get the OBC out of the dash board.
u need to remove the heater panel and headunit and undo the 4 obc screws from the back. theres a useful obc guide in the articles section which will help u out i'm sure. my obc is playing up and being an ass but ive not long installed it, so i will wait till some more enthusiasm comes along before i have it all apart again! good luck matey
Greeny
Post Wed Nov 08, 2006 4:57 pm
thank's buddy, i'll have a look at the articles. Bleeding fingers crossed.
orangecurry
Post Wed Nov 08, 2006 5:01 pm
or...
you can remove the instrument cluster (8 screws?) and pull the yellow OBC loom connector out from the back centre (and reconnect it)
make sure the OBC fault has cleared before you put the cluster back :D
tomtomiS
Post Wed Nov 08, 2006 5:07 pm
orangecurry wrote:or...
i would second that! so much less hassle plus u wont lose all ur presets on radio
