elec windows not working
t5psr
Post Wed Nov 08, 2006 7:26 am
Hi, my electric windows have ceased working i have checked the fuse and according to the handbook it also powers the sunroof but that is working fine, I have no power to the switches as they don't light up like the s/roof does, I suspect a relay or something similar. Does any have an idea and where it's located. thanks Phil
1987 m-tec 1 e30 2.7sport les stannard conversion
grimbleweed
Post Wed Nov 08, 2006 8:41 am
I have same problem but my switches light up ?
Post Wed Nov 08, 2006 9:00 am
If it's all wired as it left the factory, the sunroof works, and the window switches don't light, then the problem is most likely to be with the window overload cut out (in front of the RH window switch). Not unknown for one of the spade connectors to just fall off this one.
Chris
Post Wed Nov 08, 2006 10:10 am
Hey, sorry to hijack your thread but i hate starting a new one with only a little question.
Should my windows work with the ignition off and the doors open? They used to but dont any more and i really miss the feature.
ricey46
Post Wed Nov 08, 2006 10:21 am
Hey Guys, Would any of you be able to gave me the part number for the Window and Sunroof relay, because BMW cant issue me with a new one Unless I have the part number?? Mine was missing when I got the car and I've got a a piece of wire with two spade clips connecting the terminals at the mo!
Cheers guys any help would be great!
Paul.
325i sport Tech1
335i Chromie - Sold
2001 E46 M3-Sold
1999 E39 M5
Morat
Post Wed Nov 08, 2006 10:32 am
thedingbat wrote:Hey, sorry to hijack your thread but i hate starting a new one with only a little question.
Yes they should. Mine only do it with the passenger door tho, it looks like the drivers door switch has died. Have you checked yours?
oze30
Post Wed Nov 08, 2006 10:56 am
Brianmoooore wrote:If it's all wired as it left the factory, the sunroof works, and the window switches don't light, then the problem is most likely to be with the window overload cut out (in front of the RH window switch). Not unknown for one of the spade connectors to just fall off this one.
What if they light up, but dont move? i think i can hear the motor or something clicking when you push the button, but nothing
TW166Y
Post Wed Nov 08, 2006 12:42 pm
probably come off the runner dude or the runner snapped?
Saying goodbye to 4-pot wrongness
Post Wed Nov 08, 2006 9:53 pm
Can't work out who's asking what now!
Anyway, relay (back of glovebox) is an ordinary five terminal (change over) relay. Nothing special about it.
Windows not working when doors open is either the door switches in need of a service, or fuse 28 blown.
Switches lit up but windows not working is usually the switches in need of dismantling, cleaning, lubricating and re assembling. Supplies to the window motors pass through the infamous door pillar plug and sockets, so these are a possibility, but these particular connectors are not usually affected since they are not always live.
The window motors themselves, assuming they are factory fit and not the hopeless dealer fit ones, are usually 100% reliable.
oze30
Post Thu Nov 09, 2006 9:29 am
Brianmoooore wrote: Switches lit up but windows not working is usually the switches in need of dismantling, cleaning, lubricating and re assembling. Supplies to the window motors pass through the infamous door pillar plug and sockets, so these are a possibility, but these particular connectors are not usually affected since they are not always live.
Right, So try different door switches??
Post Thu Nov 09, 2006 9:36 am
Strange thing about this is that both don't work. Did they fail at different times?
grimbleweed
Post Thu Nov 09, 2006 12:11 pm
Brian,
Could there be a problem with an earth no connecting - mine both stopped at the same time - lights work on switches and go out when i actuate overload switch on dash. But no movement in either window. Heater etc and sun roof fine
oze30
Post Thu Nov 09, 2006 12:25 pm
Brianmoooore wrote:Strange thing about this is that both don't work. Did they fail at different times?
Unsure as i bought the car like that. Would it be worth pulling them out or spraying the crap out of them with wd40?
t5psr
Post Thu Nov 09, 2006 4:21 pm
Hi, I checked from what brian said about the spade connector in front of the right elec window switch, but mine has been altered from the original to accomadate the alarm (scorpion 737 fitted from new ,label says manufactured 1986!) so I think the problem is linked into this somehow. going to ask a mechanic friend to have a look, thanks Phil
