tyre pressure for 15" bbs
dom-1984-320i
Post Wed Nov 08, 2006 12:07 am
just a quick one.... what do you guys think is the best tyre pressure (front & back) for 15" Cross spoke BBS alloy's?
316eyes
Post Wed Nov 08, 2006 12:28 am
BMW recommended pressures vary from model to model, tyre speed rating, and also number of passengers.
Full details in back of owners manual.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
tomtomiS
Post Wed Nov 08, 2006 1:34 am
do u not have the small plaquard on the drivers door shut it lists recommended pressures for all wheels for the particular model of car. my car takes 2.4 bar on fronts and 2.6 on rears for bbs wheels. seems high but the tyres are wearing evenly so i go with what the holy book says :)
tomtomiS
Post Wed Nov 08, 2006 1:35 am
i think for a 320i they are 2.1 bar on rear and 2.0 on front. im not an anorak, i used to fit tyres for bmw dealership
Cyruz
Post Wed Nov 08, 2006 1:51 am
50psi in the rears ;) Will insure muchos fun and nasty tyre wear...
andyp
True Old Skooler
Post Wed Nov 08, 2006 10:51 am
i have 28 all round on all my cars.
Fushion_Julz
Post Wed Nov 08, 2006 12:59 pm
My 325 has 15" and 225/50/15 Bridgestone S02s
Different tyres respond to different pressures in different ways but I found that the manufacturer recomended pressures (as on the door plates), and bearing in mind the std tyre size is 205/55/15, were a bit too high. Lowering the pressures to 2bar all round gave a hugely improved turn-in and much less skittish feeling from the steering, especially in damp/drying conditions....
Correct pressure will result in the tyre heating up evenly over the surface and wearing evenly, too...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
DaveD
E30Zone Wiki Specialist
Post Wed Nov 08, 2006 2:38 pm
i use 30 f 32 r i also found the standard pressures made the ride a little hard and skittish
do you have any probs with the 225/50's as i am thinking of fitting them
billgatese30
Post Wed Nov 08, 2006 2:40 pm
DaveD wrote:i use 30 f 32 r i also found the standard pressures made the ride a little hard and skittish
snap :cool:
Fushion_Julz
Post Wed Nov 08, 2006 3:56 pm
none at all...rolling radius is within tolerable limits and the ride and roadholding are as good as on std size rubber...
My suspension is totally stock and not sport, either
