tyre pressure for 15" bbs
dom-1984-320i
just a quick one.... what do you guys think is the best tyre pressure (front & back) for 15" Cross spoke BBS alloy's?
316eyes
BMW recommended pressures vary from model to model, tyre speed rating, and also number of passengers.
Full details in back of owners manual.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
tomtomiS
do u not have the small plaquard on the drivers door shut it lists recommended pressures for all wheels for the particular model of car. my car takes 2.4 bar on fronts and 2.6 on rears for bbs wheels. seems high but the tyres are wearing evenly so i go with what the holy book says
tomtomiS
i think for a 320i they are 2.1 bar on rear and 2.0 on front. im not an anorak, i used to fit tyres for bmw dealership
Cyruz
50psi in the rears ;) Will insure muchos fun and nasty tyre wear...
andyp
- True Old Skooler
i have 28 all round on all my cars.
Fushion_Julz
My 325 has 15" and 225/50/15 Bridgestone S02s
Different tyres respond to different pressures in different ways but I found that the manufacturer recomended pressures (as on the door plates), and bearing in mind the std tyre size is 205/55/15, were a bit too high. Lowering the pressures to 2bar all round gave a hugely improved turn-in and much less skittish feeling from the steering, especially in damp/drying conditions....
Correct pressure will result in the tyre heating up evenly over the surface and wearing evenly, too...
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
DaveD
- E30Zone Wiki Specialist
i use 30 f 32 r i also found the standard pressures made the ride a little hard and skittish
do you have any probs with the 225/50's as i am thinking of fitting them
billgatese30
snapDaveD wrote:i use 30 f 32 r i also found the standard pressures made the ride a little hard and skittish
Fushion_Julz
none at all...rolling radius is within tolerable limits and the ride and roadholding are as good as on std size rubber...DaveD wrote:i use 30 f 32 r i also found the standard pressures made the ride a little hard and skittish
My suspension is totally stock and not sport, either
